Engine Stalls
Old Feb 3, 2007 | 11:23 AM
bscott's Avatar
bscott
Default Engine Stalls
Hello I have an 84 Mustang for my daughter and have replaced alternator, Battery and selinoid. While driving the car and turn blinker or lights the car will just stop and have to jump start. But if let sit for long time it will start with out a jump.
Any Ideas.
Old Feb 3, 2007 | 12:17 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: Engine Stalls
Have you tested the output of the charging system to see if it's working correctly. That's the first thing I would do.
Old Feb 3, 2007 | 12:34 PM
bscott's Avatar
bscott
I will do that and what should the output be for 3.8 V6. And if it is good what else would it be.
Old Feb 3, 2007 | 12:41 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
While running the charge output should be around 13.5-14.2 volts. You should also have the amperage of the alt output checked as well. Under full charge load, w/e the alt is rated at, the output should be very close to that. have it checked at a local shop you trust.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
TfcCDR
Sep 14, 2015 12:08 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
