headlight removal on '91
Old Oct 14, 2004 | 04:06 PM
user01's Avatar
user01
Default headlight removal on '91
I'm having a moisture problem in my headlights on my '91 2.4L convertible. Can anyone tell me how to go about removing them so that I can dry them out? I don't want to just go in and start trying different screws (don't want to mess up my alignment). Thanks a lot!
Old Oct 14, 2004 | 04:58 PM
OneGearhead's Avatar
OneGearhead
Default RE: headlight removal on '91
honestly, youre probably better off gettin brand new ones. it has a leak/hole somewhere to where water gets in. either that, or just drill holes in the bottom of it. on the bottom lip where the front meets the bottom. ive drilled like 4/5 holes in each of mine, and it pretty much remedied the problem. except for when theres a TORRENTIAL rain shower, then, im s.o.l. but other than that, it works !
Old Oct 14, 2004 | 10:50 PM
Obsol3te's Avatar
Obsol3te
Yeah, theres a crack somewhere in your headlight so it's going to keep bringin in moisture eventually yellowing it really bad.
May want to just get new headlights
But to remove the headlights isnt hard at all
There's only 3 nuts to remove
Looking at the driver side one
Theres two on the right side of it
Directly over eachother
and one in the middle ish on the left side of it(looking straight at the car)
Old Oct 15, 2004 | 02:59 PM
roundman's Avatar
roundman
why bother removing the whole thing when all you have to do is remove the bulb and stick the exhaust of a vacuum cleaner hose up to the hole to dry out the interior of the box. let it run a while and put some petroleum jelly around the O-ring on the bulb before you re-install it to help seal out the moisture. this is only a temporary fix, but lots easier than removing the headlight box!
Old Oct 18, 2004 | 01:02 PM
user01's Avatar
user01
Thanks guys! I got the light off and drilled a couple holes in the bottom. Maybe that'll work for a while.
Thanks again!
Old Oct 18, 2004 | 01:23 PM
roundman's Avatar
roundman
you shouldn't have drilled the holes as this just lets moist air get in the box and it will condense on the inside again.
Old Oct 18, 2004 | 03:19 PM
vfast's Avatar
vfast
I ♥ Acer
ha that jelly*L*
you can't tell these kids sh it*LOL* huh?
Old Oct 18, 2004 | 03:26 PM
roundman's Avatar
roundman
does seem that way sometimes don't it! LOL
seems like some of them must learn things the hard way or they don't learn it at all!
Old Oct 18, 2004 | 03:27 PM
vfast's Avatar
vfast
I ♥ Acer
yeah..sounds like us 20 years ago*LOL*
Old Oct 18, 2004 | 03:31 PM
roundman's Avatar
roundman
more like 35 years ago in my case! LOL
