Emblems
Old Feb 11, 2007 | 02:47 PM
retmil's Avatar
retmil
Default Emblems
Could someone please tell me how to remove the fender emblems from an 04? I think those 40th anniversary badges are for the birds and wish to replace them with maybe GT emblems. Thanks!
Old Feb 11, 2007 | 04:10 PM
wythors's Avatar
wythors
Default RE: Emblems
Heat is your friend. If you have a heat gun, it works best but a hairdryer can be used if you're patient. First heat the emblem up a bit. Then, you can do one of two things. Some people recommend running a piece of fishing line behind the emblem to separate the emblem from the body. My preferred method is to use a nylon prybar I have to pop the emblem off. Either way, there will probably be a little residue left. I use a dab of "Goof Off" on a rag to remove it. After that, you'll probably need to hit the area with a little cleaner-wax or polishing compound to clean up the area.
Old Feb 11, 2007 | 06:12 PM
retmil's Avatar
retmil
Default RE: Emblems
Thanks for the info! Really appreciated. Will give it a go as soon as it warms up here in Maryland.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Mustangmalo
Sep 14, 2015 10:23 AM
Mustangmalo
Sep 14, 2015 06:23 AM
Chris07GT
Sep 1, 2015 07:11 PM
dseg
Aug 8, 2015 09:00 PM
