C4 flexplate question
Old Feb 16, 2007 | 11:28 AM
racinrickshaw's Avatar
racinrickshaw
Default C4 flexplate question
I have what I think is the small bellhousing C4 and am wondering if both size flexplates will work or if I need the 157 tooth flexplate. I have a 164 tooth. I also recently bought a converter for the 164 tooth, so I hope it will work. Any help would be very helpful.
Old Feb 17, 2007 | 01:18 AM
bobbyward's Avatar
bobbyward
Default RE: C4 flexplate question
if your flywheel is larger then you will have to use a bellhousing that
takes a flywheel that size, there are at least 2-3 different v8 housing
good luck finding the matching one you need.......................
Old Feb 17, 2007 | 08:57 AM
davnsam6's Avatar
davnsam6
The c-4 bell housing are removable though they are differant besides being big or small ,they bolt up differant depends on if its case filled or pan filled, stuff like that.TCI i found is the best and cheapest way to get what your after ,flexplate and bell housing would run about 200.00 or you can check your local pick-n-pull. look through summits or jegs online catolog for what you need
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
