Super dumb how to question
Old Feb 22, 2007 | 07:02 PM
antv20's Avatar
antv20
Default Super dumb how to question
I need to replace the review mirror on my 2000 Stang. How does the old one come off? Replacing it with OEM. Mirror cracked in original. Thanks.
Old Feb 22, 2007 | 07:08 PM
P Zero's Avatar
P Zero
Default RE: Super dumb how to question
There should be a set screw. It should be on the black tab part that is closest to the windshield. It should be a small allen head screw. Remove the screw and pull the rearview mirror assembly up towards the roof. Be careful not to pull too hard, there is a tab that mounts to the windshield that you do not wanna break off, because you could crack your windshield.
-P.
Old Feb 23, 2007 | 12:08 PM
antv20's Avatar
antv20
Thanks! Anyone have an idea of what size allen it is?
Old Feb 23, 2007 | 05:28 PM
antv20's Avatar
antv20
I was told there is no set screw in there. That you actually take a small flat screw driver to get it loose from the mount. Anyone know for sure?
Old Mar 6, 2007 | 01:48 PM
blacksheeps11's Avatar
blacksheeps11
I don't know about the screw part, but if you need to get that pesky tab off, just take a bic lighter, and hold the flame on the tab, and not the glass, for 15-30 sec., then it will come right off, no window damage. Dont do this in cold weather though. It sounded bs to me too, but I've done it several times.
Old Mar 6, 2007 | 10:26 PM
Jurnymn's Avatar
Jurnymn
Drop by a shop somewhere and ask a mechanic. I'm sure they'd tell you right.Be real careful with screwdrivers or lighters. Glass can crack so freakin easy.
Old Mar 7, 2007 | 12:37 AM
Li0nHart's Avatar
Li0nHart
ORIGINAL: blacksheeps11
Do NOT take the tab (mount) off of the window...otherwise you will have to epoxy it back on agian when you replace the mirror. Go to wally world and get a cheap set of allen keys...i got a set for like 2 bucks....
Old Mar 7, 2007 | 12:31 PM
blacksheeps11
I wasn't suggesting taking the tab off, that was more of a future reference type of deal.
Old Mar 7, 2007 | 07:15 PM
p1bigun's Avatar
p1bigun
most nrear views are held on with some sort of screw just loosen the sre w and slide the mirror off the ones i have dealt with where allen but who knows just look at the bottom of the base to see
chrisdbassplayer
Oct 13, 2015 06:53 PM
treesloth
Sep 28, 2015 07:03 AM
Suree_Mustang_2009
Sep 25, 2015 12:58 PM
M3hunter
Sep 5, 2015 03:42 PM
