Alignment after spring install?
Old Oct 29, 2004 | 12:30 AM
Cedarkill's Avatar
Cedarkill
Default Alignment after spring install?
I'm thinking about installing 1" lowering springs in my '96 GT. To do the fronts, i was told it would be easiest to unbolt the top of the strut from the strut tower and lowing the whole a-arm and strust to get the spring out and new one in. Does this mean I will have to get it re-alignment? Would I have to get an alignment with the lowered springs, regardless of how the springs are put in?
Old Oct 29, 2004 | 12:32 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Alignment after spring install?
make sure you take it off from the bottom and lower the a-arm ... you won't "need" an alignment for a 1" drop but it would be a good idea.
Old Oct 29, 2004 | 05:50 AM
94Cbra's Avatar
94Cbra
Alignments arent expensive and dont take much time, go ahead and get an alignment so you dont cause adverse wear on your tires.
TimeLord101
Sep 4, 2015 09:27 AM
Luke9222
Sep 4, 2015 06:46 AM
Sep 1, 2015 08:16 PM
