slicks
Old Nov 3, 2004 | 10:19 PM
jamal420's Avatar
jamal420
Default slicks
i am looking to purchase a set of slicks for my stang and was wonderign what will give me the best bang for the buck, i am not too concerned about perfect preformance but i woudl like to hook up better i want a decent priced decent lastign slick
Old Nov 3, 2004 | 10:28 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: slicks
if your not "too" concerned with performance may I suggest a drag radial tire so that you can have good traction on the street too? Something like a Nitto 555r if you do alot of driving or BFG's if you don't and want alittle more stick at the expense of how long they last.
Old Nov 3, 2004 | 11:28 PM
bull8t's Avatar
bull8t
Default RE: slicks
Is your rear beefed up? Ok, that sounded gay. If not you may wanna beef up the rear before running slicks back there.
Old Nov 3, 2004 | 11:35 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: slicks
ORIGINAL: bull8t
I knew something was wierd about you always checkin out my **** and shizz.. its ok though I know its nice
Old Nov 4, 2004 | 01:45 AM
Obsol3te's Avatar
Obsol3te
Default RE: slicks
Stock 8.8 is pretty solid.
Just if you run slicks DO get a Driveshaft Safety Loop...
I don't have one yet, so I'm just contradicting myself.
BUT it's better than pole vaulting yourself into a wall when your driveshaft decides to go
Old Nov 4, 2004 | 02:11 AM
94Cbra's Avatar
94Cbra
Default RE: slicks
I would sugest looking into these companies for slicks
Interco Tire
www.intercotire.com
Mickey Thompson
www.mickeythompsontires.com
Hoosier
www.hoosiertire.com
Most of the above companies can be purchased through Summit ( www.summitracing.com ) for a reasonable price.
Old Nov 4, 2004 | 01:32 PM
roundman's Avatar
roundman
Default RE: slicks
I've had two sets of Hooiser slicks and both of them had problems which resulted in early failures. First set has a tiny pinhole leak that was a real nuisance, kept having to put air in it all the time and it was in the side near the bead where you couldn't really get a patch on it easily. Second set I ran over a rock at the track right at the edge of the tire and puntured the damn thing. Put a tube in it and it went flat on me again as I was pulling off the track after a pass earlier this year. I decided to hell with Hooiser and bought some Mickey Thompson ET Drag slicks with tubes and are very happy with them so far. you can fit a 26x9 slick without any problems on the stock rims for a Fox model. this last pair I went up to a 28x10.5 taller tire and had to do just a little fenderwell clearancing work to make sure nothing would hit the tire and I removed the outside quad shocks also.
I've been telling OB all year he needs to get that driveshaft safety loop too. most tracks require them if you run slicks and they are a very good safety feature to have when running slicks. never can tell when you might snap a front U joint on a shift!!!
ctgreddy
Oct 14, 2015 09:05 PM
Dragonus18
Sep 9, 2015 01:21 AM
gearhead4ever
May 23, 2004 04:43 AM
3000ways
Apr 27, 2004 04:37 AM
03gtvt
15
Nov 12, 2003 12:13 AM
