Fuel Injectors
Old Nov 4, 2004 | 01:44 PM
DaGGer's Avatar
DaGGer
Default Fuel Injectors
ok well i was wondering what the difference in fuel injectors was...i mean they have bigger ones and i wondered what they did for performance...thanks
Old Nov 4, 2004 | 02:24 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: Fuel Injectors
bigger injectors just supply more fuel. if you arent already running the max hp for the size you have, you wont notice any performace change...ex. if you have 200hp going to 24# injectors wont make any difference. you may notice something but thats only cause your switching from old injectors to new ones. if your running 300hp on the 19# injectors, you should notice a change when going to 24
Old Nov 4, 2004 | 02:48 PM
Obsol3te's Avatar
Obsol3te
Speaking of when Injectors max out.
Anyone know when 24's 30's etc max out?
Just make a list would be nice
24:
30:
36:
etc...
Old Nov 4, 2004 | 03:03 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
OB things like fuel pressure will affect the flow of injectors, for example a stock set of 19# injectors will max out at a 90% duty cycle at 304 hp, whereas bumping the pressure to 45 psi you can squeeze 345 hp outta em.
But, I suppose if the injectors were run at the stock 39 psi then:
19# = 304
24# = 384
30# = 480
36# = 576
42# = 672
Now this assumes a bsfc of .45 - a supercharged car is gonna consume more fuel - more like a .55 bsfc (because you'll be running a much richer a/f ratio) so in the case of a supercharged car then your only gonna get 314 hp out of 24# injectors.
Also, remember this is flywheel horsepower - and that you ideally wanna be around 70% duty cycle, not 90%
If you wanna figure it up yourself its pretty symple. Just remember that Ford rates their injector flow at 39 psi, so if an injector flows 19# of fuel and you have 8 cylinders then if they were stuck wide open you'd flow 152 #'s per hour at 39 psi. You've got a max duty cyle of 90% so you take 152 x .9 = 136.8 #'s into the cylinders max. A na performance motor usually has a bsfc (brake specific fuel consumption) of .45, a supercharged car around .55 ... so take that 136.8 / .45 for a na performance engine and you've got 304 hp. If you increase fuel pressure from 39 psi to 45 psi then you've increased it by roughly 13.5%, so you can support 13.5% more hp, or 345 hp.
Class dismissed.
Old Nov 4, 2004 | 03:07 PM
Obsol3te's Avatar
Obsol3te
Heh, didn't even think of having to run richer=less hp out of the injectors...
Thanks
That's why my injectors arnt flowing enough for the 150...
Bleh
Had to up the Fuel Pressure a bit just to run the 75 with my current mods
Oh, well buying new injectors soon anyways
Old Nov 4, 2004 | 10:20 PM
roundman's Avatar
roundman
nice job with the explanation there Joe, but don't know if OB can understand all that technical stuff! LOL
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
