rear end howl
Old Nov 7, 2004 | 11:42 PM
tyybo's Avatar
tyybo
Default rear end howl
K i had my gears installed(3.73 ratio in the 95GT) about a month or so ago and over third gear they howl like crazy. ive been told its not a big problem, but its annoying as hell is ther any thing i can do to quiet them down some?
Old Nov 7, 2004 | 11:44 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Default RE: rear end howl
What kind of gears are they?
Old Nov 8, 2004 | 12:12 AM
Redline03GT's Avatar
Redline03GT
What exactly do you mean howl?
Old Nov 8, 2004 | 12:28 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Well, most of the time you will get some gear noise (less often with FMS gears), some gear manuf even say that gear whine is to be expected. Now, is it whine (as in gears) or a howl (as in bearings)? If the backlash is alittle on the tight side thats cool, but... does the noise come and go with gas or is it there all the time?
Old Nov 8, 2004 | 12:34 AM
tyybo's Avatar
tyybo
k if you really nail it, it dosent really make the noise, just if you kinda have your foot on the gas like daily drivin
and really only in 3rd gear up. and i think its river side gear? i dunno its an ebay thing this is the kit i got
http://cgi.ebay.com/ebaymotors/ws/eB...932577990&rd=1
Old Nov 8, 2004 | 12:37 AM
devinsteen's Avatar
devinsteen
[sm=noooo.gif] The howling you here is not a good thing. It won't really hurt anything, but you don't want to let it go for too long. I had the same problem with my gears....the damn howl is so annoying [:@] Mine would hit at about 35mph when I let off the gas. THe backlash may be little off, but when I did it setting the backlash was not that hard. My problem, which may be yours, was that the pinion nut was not tight enough. You want to make sure you tighten it until there is no lateral movement.....but not too tight! You can use a torque wrench or jsut tighten it in small increments until there is no movement. Hope this helps[&:]
Old Nov 8, 2004 | 12:42 AM
Acer2428's Avatar
Acer2428
Site Mod
No name gears = PWNED
Old Nov 8, 2004 | 04:54 AM
94Cbra's Avatar
94Cbra
I would say the howl isnt good and needs to be fixed. My old 96gt as well as my Cobra have 3.73's and are whisper quiet. Sound like I never opened up the rear diff.
Old Nov 8, 2004 | 12:20 PM
roundman's Avatar
roundman
good gears properly installed and set up should not be whining at all.
Old Nov 8, 2004 | 03:01 PM
devinsteen's Avatar
devinsteen
ORIGINAL: roundman
[sm=exactly.gif] That is what I was saying
