still ticking
Old Nov 9, 2004 | 03:26 PM
roundman's Avatar
roundman
Default RE: still ticking
trying dropping the timing back down to 10 degrees and see if the noise goes away. this is the stock level and with the new heads, you may be pushing the envelope trying to use 89 octane with the new compression of the new heads. if the noise does go away, then you need to run the higher octane gas. if it don't, then I would pull the passenger side valve cover and inspect everything, springs, keepers, rockers, pushrods, etc. until I found something cracked or loose or binding and hitting.
Old Nov 9, 2004 | 04:39 PM
cammedlx's Avatar
cammedlx
i can't belive anybody has said this EXHAUST LEAK that is probaly what it is
Old Nov 9, 2004 | 05:37 PM
luckythirteen13's Avatar
luckythirteen13
well i had the valve cover off yesterday...didnt notice anything out of the unusual. everything was fine and nothing had come loose.
exhaust you say.... ill check to make sure the bolts are tight when i get home. and ill set my timing back...they told me they set it to 18* first and i almost **** my pants. he said it had detonation so they turned it back to ABOUT 14*
Old Nov 9, 2004 | 06:15 PM
bobby's Avatar
bobby
YUP! i wonder why i didnt think f that, i am 99% sure that is ur problem, it does sounds just like a rocker tiking! DUH!!!
ORIGINAL: stangpower96
Old Nov 9, 2004 | 07:06 PM
vfast's Avatar
vfast
I ♥ Acer
could be..
Old Nov 9, 2004 | 11:42 PM
luckythirteen13
its a felpro...the header gasket that is.... you think tightening the bolts would do it or would i need a whole new gasket. its a b!tch to take those headers off and put them back in.
Old Nov 10, 2004 | 01:36 AM
bobby's Avatar
bobby
try tightenign them, they will come loose, if not, u need a new gasket, and why arent u answering my IM'S!!![:@]
Old Nov 10, 2004 | 02:08 AM
luckythirteen13
sorry bobby, had to take my g/f home....and test out my stang
Old Nov 10, 2004 | 04:20 PM
vfast's Avatar
vfast
I ♥ Acer
what about testing the girl friend?*L*
Nick Oliver
Oct 17, 2018 04:22 AM
69Volunteer
Sep 30, 2015 10:39 AM
Sixer4Life
Sep 28, 2015 07:05 AM
Shadow7874
Sep 24, 2015 09:06 PM
Emblazoned
Sep 3, 2015 10:45 PM
