check engine code?
Old Mar 23, 2007 | 12:41 AM
wildazme's Avatar
wildazme
Default check engine code?
i got a check engine light and when i checked the code im getting P0420 catalyst system efficiency below threshold (bank 1) what does that mean exactly? im thinking a bad oxygen sensor. any help is appreciated thanks.
Old Mar 23, 2007 | 02:04 PM
blacksheeps11's Avatar
blacksheeps11
Default RE: check engine code?
It sounds like yourcat on bank oneisn't working properly. If your 02 sensor was bad it would give you a code saying so. If your cat isbadit won't let exaust flow properly, and won't work "efficiently" I would either check it out myself, or have someone who knows check it out for you. Sometimes if you run rich for a while, the excess fuel will get into the cat, and mixed with the high temps inside, and melt the honeycomb inside, thus working below efficiency threshold.
Old Mar 23, 2007 | 02:53 PM
96GT226410's Avatar
96GT226410
CSMG Moderator
It could still be an O2. Check the voltage. Make sure it's switching back and forth from around .1V - .9V and even if it is, it still may be bad.
Old Mar 23, 2007 | 02:57 PM
wildazme's Avatar
wildazme
changed out all the o2's and so far seems like the problem is gone. hope it stays gone.
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
