help knocking sound
Old Apr 2, 2007 | 07:29 PM
bowlburner's Avatar
bowlburner
Default help knocking sound
as soon as i let my clutch out and giive the car gas there is a knock sound and u can feel it in the floor boardalso when i let off the gas u can feel it again. but its not a constant knocking. it just doues it each time u get on or of the gas and the car flexes.
Old Apr 2, 2007 | 08:10 PM
dirtystang04's Avatar
dirtystang04
Default RE: help knocking sound
Sounds like maybe a bad U joint. I would check them first and then move to the rear from there.
Old Apr 2, 2007 | 09:02 PM
mariotraci's Avatar
mariotraci
exhausthitting the floor?
Old Apr 3, 2007 | 08:59 PM
bowlburner's Avatar
bowlburner
it also does it when the car decellerate
Old Apr 4, 2007 | 09:22 AM
corvetteguy's Avatar
corvetteguy
Possible that the trans cross member has
rusted out or is loose. The torque on the
trans causes it to move in the mount.
Old Apr 4, 2007 | 09:24 PM
bowlburner's Avatar
bowlburner
well i just got rear ended when it started hapening
Old Apr 5, 2007 | 09:25 AM
corvetteguy
You need to get some lift time.
Look at the exhaust pipes and see
where they have moved too close to the
body or drive shaft.
Old Apr 7, 2007 | 01:45 PM
bowlburner's Avatar
bowlburner
found out waht it was my transmission mount was loose my rear sway bar and one of my control arms were also loose. but all is well now
Old Apr 7, 2007 | 11:57 PM
kenv's Avatar
kenv
Could have broken a motor mount
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
