OIL LEAKS...
Old Apr 6, 2007 | 07:17 PM
drewy8788's Avatar
drewy8788
Default OIL LEAKS...
i just got some ford racing valve covers and put them on and it turned out that there were a few leaks. two coming out of a couple of the bolts holding on the valve cover and one in the passenger side rear. I decided to take the car into the shop and have my buddy look at the car and fix all the leaks. They did the valve covers over again and the same thing is still happening. He said there was a tight seal so i dont know whythey are leaking so much. Its an 89 mustang gt. No roller rockers. thanks alot
Old Apr 7, 2007 | 03:24 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: OIL LEAKS...
Sounds like they're warped.
Old Apr 7, 2007 | 11:22 AM
The Jackal's Avatar
The Jackal
Manufacturing fault for the covers!!
Old Apr 7, 2007 | 04:01 PM
Li0nHart's Avatar
Li0nHart
put a little rtv silicone between the gasket and valve covers. not quite as convenient for quick removal but it should stop the leaks.
Old Apr 8, 2007 | 01:25 AM
kartracer55's Avatar
kartracer55
What kind of gaskets are you using? Cork or Rubber?
Cork gaskets suck and are prone to leaking. If you are using them, make sure you use RTV around them. The valve covers may not be warped, it might just be the fact that the cork gaskets are ****ty gaskets to begin with and do not compress/seal as well as rubber ones. Get some high end gaskets and be done with it.
Jim
Old Apr 8, 2007 | 06:31 PM
Colorado_Mustang
I use cork gaskets siliconed to the valve covers. Never had a leak. Tried rubber gaskets...leaked likea *female dog*.
Old Apr 9, 2007 | 02:25 AM
kartracer55
ORIGINAL: Colorado_Mustang
I have had lotsa bad luck with cork gaskets. What happens is as you compress them, the cork develops small cracks in it. When I MUST use cork, I use the correct type of RTV on BOTH SIDES.
For example, Many (all?) Ford transmission's use reusable rubber pan gaskets. When you do a service on these things every 30K, you need to drop the pan to change the filter. I have reused the rubber gaskets 3+ times on cop cars without any problems. The key is a good gasket. The cork gaskets you get, even from WIX simply dont seal as well as the rubber ones.
wraith777
Sep 28, 2015 10:49 AM
Shadow7874
Sep 24, 2015 09:06 PM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
kevsgt
Sep 9, 2015 06:20 AM
