shocks and struts install
Old Nov 23, 2004 | 01:14 PM
gr8white's Avatar
gr8white
Default shocks and struts install
I was just quoted 500.00 labor for KYB Shocks, struts and ford racig springs to be installed on my 88 GT. This is the reason I am trying to get some info on installing the parts I bought myself. How hard would it be to install everything in a driveway with basic hand tools. any tips or advice would greatly appreciated.
Old Nov 23, 2004 | 02:20 PM
primetime5.0's Avatar
primetime5.0
Default RE: shocks and struts install
hey i just installed all those same parts on my car. its actually more simple than you think, first you can get the front springs out without compressing them just disconnect all the hard ware and step on the a-arm and the spring will pop out as for the strut is was a little more tricky we had to take it completely off and cut the bolt off the top because after 16 yrs it wouldnt budge. the rears are even easier all you have to disconect is the quad shock and compress the sprind then step on the rear end and the spring will come out, to install you dont even have to compress just have someone step on the side that your doing and just slide the new spring back in, its actually very simple job to do it only took me and a buddy a few hours to do.. GOOD LUCK!
Old Nov 23, 2004 | 03:28 PM
slo93aod's Avatar
slo93aod
just be carefull, that spring could kill you LOL
its really easy to do, just take your time and be carefull
Old Nov 23, 2004 | 03:32 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
You don't NEED a compressor, but I suppose its helpful. And, um yea I've heard some stories of horrible spring deaths... also seen a coil spring get shot up a good 200 feet in the air [sm=alien.gif]
Old Nov 23, 2004 | 05:33 PM
gr8white's Avatar
gr8white
thanks for the help i just added it to my winter project list
Old Nov 24, 2004 | 11:19 PM
bobby's Avatar
bobby
seriously?
ORIGINAL: mdvaldosta
Old Nov 25, 2004 | 03:30 PM
fastmustangs1's Avatar
fastmustangs1
It shouldn't be very difficult as long as you know how to do it. A extra set of hands would also help. It is
a lot easier on a lift than floor jack and stands though. Good Luck,
Matt 01 stanger
Old Nov 25, 2004 | 03:38 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
floor jack is the only way to do it without a spring compressor
mtgldr
Feb 3, 2024 09:00 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Luke9222
Sep 4, 2015 06:46 AM
Sep 1, 2015 08:16 PM
