HELP - problems with 02 Mustang
Old Nov 23, 2004 | 07:05 PM
Autosport's Avatar
Autosport
Default HELP - problems with 02 Mustang
Hello all - A little new to this Forum and from "Down under" (Australia)
I have a 5.6L MY02 quad cam Mustang that I fitted a Vorte supercharger to, The thing make 500hp now EASY..
Problem is now that at speeds above 150km/h the car wants to lift off the ground. Where can I source a rear wing and front body moulds to help stabilise the car at high speed?
Also, looks like I've damaged my 5 speed Maual gear box with the power. What gear box conversions are available for the Mustang that will hold the power? (car has to stay street driveable)
Nothing is available here in Australia so any help would be greatly appreciated. (any vendors feel free to email me direct damian.zanetti@au.unisys.com but am interested to hear all soments.
thanks .
Old Nov 24, 2004 | 01:40 PM
roundman's Avatar
roundman
Default RE: HELP - problems with 02 Mustang
try www.cervinis.com or www.steeda.com for body kits
Old Nov 24, 2004 | 03:33 PM
primetime5.0's Avatar
primetime5.0
put a t-56 in it it'll handle almost anything
Old Nov 26, 2004 | 03:17 AM
Miliock's Avatar
Miliock
ummm maybe going over 150mph might be a bad idea......
Old Nov 26, 2004 | 03:42 AM
911ss's Avatar
911ss
ORIGINAL: Miliock
i think he said 150 kilometers. but 150 mph works for me... anyways, id check steeda on the body kit and maybe a new suspension....
Old Dec 3, 2004 | 01:05 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
The Cobra R kit is what you need.
Old Dec 3, 2004 | 02:24 PM
Birdieman4's Avatar
Birdieman4
First off, welcome to the forums. A couple points about areodynamics. First, the main reason your car gets 'light' in ther front end is your stock hood is acting like a parachute, causing a lifting effect. If you get an aftermarket hood with large vents it will greatly improve the 'lightness' of your car at speed. A wing will help a little, but mostly it will provide stability and not help the lightness feeling that much in front. The best hood for speed you can get is probably the Saleen S281E hood. It has huge vents. An areo kit will help stability a lot. Again, the best body kit for speed and areodynamics is probably Saleens.
Like someone said above, get the T56 tranny. It can take big hp, and is designed to do so. With the power you'll be makin' with that 5.4 blown motor will need this tranny.
matthockey32's Avatar
matthockey32
I ♥ Acer
5.6l quad cam. where did you get that and can i have one?
Old Dec 4, 2004 | 02:06 PM
Dan04COBRA's Avatar
Dan04COBRA
First, if you can, lower your car & put a Mach 1 chin spoiler on. Also, if you don't mind you can remove your fake hood scoop....
Old Dec 4, 2004 | 04:29 PM
Acer2428's Avatar
Acer2428
Site Mod
Aussies have lower emissions and MOG requirements like us in the states. So they get bigger badder engines. For being the home of the "American Muscle Car" we have some of the weakest cars around the world.
