351c problem please help
Old Apr 8, 2007 | 07:20 PM
frodojv2007's Avatar
frodojv2007
Default 351c problem please help
well im 18 years old and i have a 1972 mustang and ive built the motor as a cleveland but it runs kinda bad i have alot of money in the motor all after market and still wont squeeq the tires my first question was is it a cleveland and im pretty sure it is and second is y does it run all slugish ive messed with the timing and nothing ive tried the firing order and it only start in the high out put firing order my last thought is that i got the wrong kind of cam maby i got a high output cam and have a stock crank??? could that be a problem maby if i get a regular cam it should run alot better that motor should hallll i mean it should scream withall the money i put in it wat else coiuld be the problem the engine is an h code but i put 4v heads with a torker intake and 650 sfm carburator and the cam is a launati cam with a 572 lift forged pistons bored 30 crank 10 iono i jus want to get it runin like i thought it would can anyone help with the identification of the engine and and jus let me know if anyone has had theis problem before thanks id apreciate it verry much
[IMG]local://upfiles/66014/A17575F0360848549A68589F893FFDA4.jpg[/IMG]
[IMG]local://upfiles/66014/AF2F8D49E66548D4AAFF593338D56600.jpg[/IMG]
Old Apr 8, 2007 | 08:27 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: 351c problem please help
Wow.....use some punctuation. PLEASE!!!
I couldn't really understand what you were asking, but I did gather you are disappointed you can't burn the tires with the engine you built.
1) Lose the scoop.
2) You won't have much torque with that intake.
3) The Edelbrock better be a 750.
4) You should have a Holley.
5) What gears you runnin'?
6) What axle do you have?
7) What size tires do you have?
8) What kind of tranny do you have?
9) Cleveland isn't how you build it, it's what it is.
10) Take a grammar course and learn to use some puncuation to have a shot at communicating with more intelligence than your average rock.
Thank you, drive on.
Old Apr 8, 2007 | 08:54 PM
Rashii46123's Avatar
Rashii46123
i agree with all of that, especialy with the grammar, your 18, senior in high school(should be), USE PUNCUATION!!!
Old Apr 8, 2007 | 11:08 PM
NeoTokyo's Avatar
NeoTokyo
Ya the bird catcher isnt going to help you much, I would get rid of that.
There are so many different problems that it could be or a combination of problem. Its hard to tell not actually being there. You should cover all the basics; Fuel, Spark, timing, firing order,vacuum, Compression, rocker clearances.
If you have roller rockers then you are 100% hitting those valve covers, those are way too short for rollers. You also might have a valve that isnt seating correctly and so many other things.
Again its hard to tell whats wrong when there are so many details left out of the mix, including trans, if its been rebuild and the rear end. In your case it would probably be a great idea ot take it to have it dyno tuned, its cheap and you will maximize power (If its not a problem with the engine that is.)
Best of luck.
-Eric-
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
