A Stupid ?
Old Apr 9, 2007 | 12:30 AM
silvermaster92's Avatar
silvermaster92
Banned
Default A Stupid ?
Ok, be4 u flame me, remember that i am 14 yrs old, and am TRYING TO LEARN about mustangs.
i know there is an overdive switch beneath the button to change gears in a auto, but what is overdive, and wat does it do?
Old Apr 9, 2007 | 12:33 AM
silvermaster92
Banned
Default RE: A Stupid ?
overdrive* srry
Old Apr 9, 2007 | 12:35 AM
whitey2007's Avatar
whitey2007
correct me if im wrong, isn't OD just like another gear with a longer ratio for better economy and lower rpm driving on the freeway to take stress off the motor.
Old Apr 9, 2007 | 01:06 AM
NeoTokyo's Avatar
NeoTokyo
ya, its a low gear like .62:1 ratio or something.
Dont worry about asking questions, there are no stupid questions. We are all born knowning nothing.
-Eric-
Old Apr 9, 2007 | 10:38 AM
Chopper's Avatar
Chopper
When an "overdrive" gear is used the output rpm is greater than the input rpm.In other words,the output shaft spins faster than the input shaft.
Old Apr 9, 2007 | 01:07 PM
silvermaster92
Banned
kk, so how do i know if the car goes into overdrive or not?
Old Apr 9, 2007 | 01:31 PM
TwotoneVert's Avatar
TwotoneVert
Count the gears. If you have a 5 speed auto, with OD, you can feel the gear change and watch the tach to confirm shift points.
Old Apr 9, 2007 | 01:40 PM
silvermaster92
Banned
ok thanks
Old Apr 9, 2007 | 01:56 PM
GreyStang's Avatar
GreyStang
And ususually if you have an overdrive "switch or button" in your car it is there to STOP overdrive from engaging. Overdrive "on" is the normal setting. But sometimes you want to stop the car from going into overdrive. Situations such as trailer towing or if you aredriving on really hilly roads you might want O/D to be off so you get better engine braking & less "hunting" (tranny constantly going in & out of overdrive each time vehicle loading changes)
Old Apr 9, 2007 | 03:52 PM
silvermaster92
Banned
when OD is off, do you rev higher?
oh and is there an OD gear on a manual car?
