Yet another problem.....
Old Apr 11, 2007 | 02:48 AM
quesswhatidrive's Avatar
quesswhatidrive
Default Yet another problem.....
well the manual is in and i have the TR sensor rigged up so it starts n drives. But my major issue is that the thing vibrates like hell its nuts like its gonna fall apart...... it does not do it at idle, but anything off of idle it shakes the whole car. Im nnot sure if its the new clutch assem. or the trans r wat it is. It does not matter which gear im in it varies by RPM, it does not vary with speed. if u guys have any ideas please lemme know im brain dead of ideas thanks
Old Apr 11, 2007 | 04:29 AM
kennebellgt's Avatar
kennebellgt
Default RE: Yet another problem.....
Isthe clutchbalanced correctly?
Old Apr 11, 2007 | 11:05 AM
Chopper's Avatar
Chopper
Has the new transmission bellhousing been checked to see that it and the new transmission are perfectly in line with each other.The transmission input shaft and the crankshaft center line must be the same or you will get a vibration like feeling and rapid clutch wear.A dial indicator is used for this measurement.
Old Apr 11, 2007 | 11:47 AM
C6Vette_Lingenfelter's Avatar
I ♥ Acer
Go figure! IT'S A FORD
Old Apr 11, 2007 | 12:39 PM
DBovine's Avatar
DBovine
ORIGINAL: C6Vette_Lingenfelter
Well there is a helpful comment
Old Apr 11, 2007 | 12:51 PM
quesswhatidrive
the clutch i am reasonably sure is in correctly, i made sure not to remove the alinment tool till everything over it was torqued. as for the bell houseing, it was attached to the tranny when i got it but ill look into that as soon as i get it bak in the air
RichM1983
Feb 8, 2013 10:17 PM
rleey07
Aug 16, 2010 08:31 PM
kane1983
4 Cylinder NA and Turbo
Mar 5, 2010 10:32 PM
93nitrousLX
Aug 25, 2008 08:28 PM
cruiser
Mar 14, 2008 08:23 PM
