ud pulleys+timing adjuster?
Old Nov 28, 2004 | 01:12 AM
Jcelli04's Avatar
Jcelli04
Default ud pulleys+timing adjuster?
i plan on getting these. any objections? what kinda of hp numbers will i get?
Old Nov 28, 2004 | 01:33 AM
STKClutch's Avatar
STKClutch
Default RE: ud pulleys+timing adjuster?
No objections they are a great mod for the money the pulleys will free up prob about 10-15 hp and the adjuster is something you will have to play with. but both are great.
Old Nov 28, 2004 | 12:08 PM
Acer2428's Avatar
Acer2428
Site Mod
And it's good to do them at the same time, less work!
Old Nov 28, 2004 | 12:55 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
I'd say pullies = about 5-6 hp & adjustor 7-8 hp
Old Nov 28, 2004 | 02:03 PM
Birdieman4's Avatar
Birdieman4
With good gas in your car I'd say with the timing kicked up, you'll get 15+ hp with the timing adjuster alone.
Old Nov 29, 2004 | 12:48 AM
Jcelli04's Avatar
Jcelli04
what should i set my timing to if I always use at least 93 octane fuel in my car
Old Nov 29, 2004 | 05:30 PM
Birdieman4's Avatar
Birdieman4
Oh, you could run quite a bit. Saleen's base powerflash calibration has the total timing set at 21', and they recommend 91 oct.. you could go 22-23 on 93.
Old Nov 29, 2004 | 06:04 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
I did those two and the exhaust all at once and it REALLY woke up my car. Now I have da 4.10's and day go like WOOOT WOOOT!
Old Nov 29, 2004 | 11:20 PM
Jcelli04's Avatar
Jcelli04
what is the timing set at stock?
if i can advance it 10 degress what should i advance it?
Old Nov 30, 2004 | 12:49 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Stock timing is 10 degrees. On a 2001+ the furthest you need to go is 14 degrees advanced. 16 degrees on the 2000-
