carb turbo
Old Apr 24, 2007 | 11:56 AM
stangant's Avatar
stangant
Default carb turbo
does anyone know how to turbo a carb motor?
Old Apr 24, 2007 | 12:21 PM
GreyStang's Avatar
GreyStang
Default RE: carb turbo
Either set up a "draw through" turbo where the carb comes first & passes the fuel/air mix through the turbo into the engine, or a "blow through" setup where the turbo comes first & blows pressurized air thru the carb. With a blow through setup you need a specialized carb that can handle boost blown through it
Old Apr 24, 2007 | 02:29 PM
67mustang302's Avatar
67mustang302
Demon now sells a series of Mighty Demon carbs that are setup for blow-through FI applications. There are others out there, but I don't know who they are.
Old Apr 25, 2007 | 10:54 AM
Chopper's Avatar
Chopper
Some people construct a box that seals in the carb for a blow through application.All you need is the same air pressure at the fuel bowl vents as is present at the carb throat.
I would prefer the draw through design myself.This way you just have to find a place to mount the carb.
Old Apr 25, 2007 | 11:04 AM
stangant's Avatar
stangant
i think ill do the draw thru since this im doing this on something that i cant get a special carb for and if you can do you know any sites with step by step instructions or can someone here explain the process. i have search and cant find any so if you can help it would be greatly apreciated.
Old Apr 25, 2007 | 01:56 PM
GreyStang's Avatar
GreyStang
What is thatcar/enginebeing turbo'ed?
Old Apr 26, 2007 | 05:05 AM
NeoTokyo's Avatar
NeoTokyo
Here are some pics to give you a better idea.
You can buy the bottom one on ebay http://cgi.ebay.com/ebaymotors/Carb-...QQcmdZViewItem
Old Apr 26, 2007 | 05:07 AM
NeoTokyo's Avatar
NeoTokyo
Those were blow throughs, here is a Draw Through.
http://cgi.ebay.com/ebaymotors/Draw-...QQcmdZViewItem
Old Apr 26, 2007 | 10:38 AM
stangant's Avatar
stangant
this may sound dum to yall but its for a fourwheeler that im dragin out it a 2 stroke so if ya got imput it would be great
Old Apr 26, 2007 | 12:58 PM
hellion_79's Avatar
hellion_79
ORIGINAL: stangant
Your givin me ideas.....
I should turbo my gas powered scooter. I actually think they sell fourwheelers stock with turbo's capable of putting out 9 pounds of boost.
