Rear Gear problem, Help!
Old Apr 29, 2007 | 10:20 AM
mik98's Avatar
mik98
Default Rear Gear problem, Help!
Hi, I have the following problem: Sometimes I cannot shift into the R gear, the shifter doesn't go in all the way (the back light turns ON though )? So I have to go a bit forward, then try other gears and then it goes in. Once its there I can shift into any other gear and back into R no problems as soon as the car is in the same position, if drive forward it happens again.
Or there is a trick that Im not aware of ? :-) Is R gear located right under 5th or its a bit further to the right?
I have 98 GT manual trans., all stock except air intake and H pipe.
Thanks a lot.
djbigskrilla
Sep 20, 2022 01:04 AM
msavoia23
12
Jul 7, 2018 12:08 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
inyadreems
Aug 21, 2015 09:10 AM
