Shifting Troubles
Old May 5, 2007 | 07:34 PM
sinnerchrno's Avatar
sinnerchrno
Default Shifting Troubles
My 2003 V-6 Mustang grinds going from 4th to 5th at high RPMs but if I take it to neutral and hold it there for a second then gently put it into 5th it goes in smooth any ideas?
Old May 6, 2007 | 12:41 AM
Zanador's Avatar
Zanador
Default RE: Shifting Troubles
Synchros. Are you rev matching when at high RPMs? If not, you are putting a lot of strain on the synchros, and are wearing them out.
Old May 6, 2007 | 04:31 AM
laserred02's Avatar
laserred02
that's normal, don't shift hard into 5th you will destroy your syncro's. give it some time in neutral before you shift at high rpms
Old May 6, 2007 | 11:15 AM
GreyStang's Avatar
GreyStang
Yup your synchros are worn out. The transmission needs to be dropped & disassembled in order to fix it. It's a big PITA that synchros themselves are really cheap, but the labor to install it is kinda pricey.
But while the tranny is out you can take advantage of it by replacing the clutch too, if it's feeling a bit tired
Old May 6, 2007 | 11:36 PM
kenv's Avatar
kenv
synchros are toast
CS2007
Jun 25, 2019 09:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
