what size push rods
Old May 6, 2007 | 10:49 AM
stang8689's Avatar
stang8689
Default what size push rods
I have a 93 block with gt-40x aluminum heads that have been shaved .25, i also have 1.6 roller rockers and an e cam. will stock length work? I am getting hardend push rods and guide plates but not sure if stock length will still work. thanks
Old May 7, 2007 | 08:47 PM
stang8689's Avatar
stang8689
Default RE: what size push rods
bump
Old May 8, 2007 | 08:28 PM
stang8689's Avatar
stang8689
bump
Old May 8, 2007 | 10:11 PM
67mustang302's Avatar
67mustang302
Maybe, maybe not. Lifter preload is supposed to be .020-.060, so if you were at minimum preload, like .025, then you'd be at around .050. Without knowing what your preload was before, can't really tell. Besides, if they're too long, just shim the pedestals(if they're pedestal mount). If they're stud, then check to see what the rocker manufacturer says on how to check rocker geometry/pushrod length. You might be fine with stock length, you might not
Old May 9, 2007 | 02:58 AM
Stangsational's Avatar
Stangsational
ORIGINAL: 67mustang302
very good point..
Old May 11, 2007 | 12:59 AM
stang8689's Avatar
stang8689
thanks for the response i have ped mount rockers so I guess i can shim than more if need, thanks didn't think of that
JayGee
Sep 15, 2015 12:41 PM
unit91
Sep 15, 2015 09:53 AM
Sep 10, 2015 08:39 PM
Other Professional Racing
Sep 10, 2015 11:41 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
