i Need help
Old Dec 14, 2004 | 01:12 PM
mike1921's Avatar
mike1921
Default i Need help
I need some help. My 99 V6 Mustang wount pass inspection because of service engine soon light is on. I took it to Auto Zone to get the code. I got Number crossed P0411 it says that The PCM has Determined that the Flow Detected in the Secondary Air Injection System is Incorrect for the current Engine Operating Conditions. I dont know how to fix it. I did not change anything. So if any one can help let me know thanks. you can contact me here or at my email at mike17162001@yahoo.com
Thanks
Old Dec 14, 2004 | 01:14 PM
619socalstang's Avatar
619socalstang
Default RE: i Need help
warranty, go to ford.
Old Dec 14, 2004 | 01:18 PM
mike1921's Avatar
mike1921
yea i allready went to ford and ask them and my warranty is up. I thought i would try to fix it myself as a little project
Old Dec 14, 2004 | 07:00 PM
Dan04COBRA's Avatar
Dan04COBRA
You have a problem with your smog pump I believe.
Some people might say it's the diverter valve, but typically it's a smog pump problem.....[&:]
Old Dec 14, 2004 | 09:37 PM
Mach1_04's Avatar
Mach1_04
Your Air Injection Pump,located under front bumper probably has water in it.You will need to replace it.Fairly easy repair.
Old Dec 16, 2004 | 02:36 AM
BlackMage's Avatar
BlackMage
i would just ask the dealership straight out, wats wrong with the car? and wat do i need to do to fix it, they should at least tell you watsd wrong for free, i think
