Steeda Timing Adjuster
Old Dec 30, 2004 | 09:12 PM
Hells GT's Avatar
Hells GT
Default Steeda Timing Adjuster
How easy is it to adjust your timing on your own without having any knowledge of doing it? Is there a guide to follow that comes with the kit? Is the timing adjuster worth buying if you know nothing about it?
Old Dec 30, 2004 | 09:18 PM
Acer2428's Avatar
Acer2428
Site Mod
Default RE: Steeda Timing Adjuster
I'm just waiting till a get a tune/tuner...
Old Dec 30, 2004 | 09:19 PM
Hells GT's Avatar
Hells GT
Does a tuner automatically adjust your timing for you though? From my understandings the timing adjuster is manually adjusted with a small tool to your personal setting.
Old Dec 30, 2004 | 09:44 PM
vfast's Avatar
vfast
I ♥ Acer
you should buy you how to hotrod your stang book the learn about the car
Old Dec 31, 2004 | 02:42 AM
04gtmatt's Avatar
04gtmatt
heres the deal i have a diablo predator can i do it with that instead of using a steeda ta itll save me abill50 if i can . word would nice thanx.
Old Dec 31, 2004 | 03:50 AM
jdaniel's Avatar
jdaniel
I ♥ Acer
Check it out. In order to adjust the timing adjuster you loosen three allen screws and the little sprocket on the outside of the pully will turn left and right freely. Then there is numbers on a stationary wheel thats held on to the pully by the crank bolt and it has numbers on it. You turn the sprocket and line up slash mark to the desired number on the stationary wheel such as 14 for 14 degrees advanced. It doesnt automatically adjust for you. 99+ GT's shouldnt be adjusted over 14 degrees advanced because the engine will often surge really hard making it a real pain to launch or drive at low speeds. Pre 99 models can be adjusted up to 16 degrees advanced beause the compression ratio is different.
Here is a link to the install so you can get a picture to what im talking about.
Steeda Timing Adjuster install.
Old Dec 31, 2004 | 04:35 AM
bobby's Avatar
bobby
thanks for the link jug [sm=smiley20.gif]
Old Dec 31, 2004 | 08:28 AM
Hells GT's Avatar
Hells GT
thats the answer i was looking for. I wasnt lookin for "yo dogg, jus by a tuner yo"
thanks J
Pyrate Dave
Sep 10, 2015 07:30 PM
RWHEELS
Sep 5, 2015 03:42 PM
Luke9222
Sep 4, 2015 06:46 AM
Sep 2, 2015 08:40 PM
Sep 1, 2015 08:16 PM
