Horn Help Needed.
Old Jun 14, 2007 | 02:15 AM
scarslilpyro's Avatar
scarslilpyro
Default Horn Help Needed.
Ok so when I got the car, the horn did not work.
I took the cover off, and I can hear the electricity hitting and making a tapping sound, but no horn.
I have an aftermarket horn kit, with the motor, 2 horns, a relay or some kind of switch thing, and the tubes.
I have a couple of questions, my first is, where is the motor and horn located at on a stock 1988 mustang gt convertible?
Second, do I need the relay thing that came with the aftermarket horn? The motor itself has a negative and positive hookup, and I will hook it up to a toggle switch.
Please respond and I will answer any questions if I left any details out, thanks.
Old Jun 14, 2007 | 09:07 AM
corvetteguy's Avatar
corvetteguy
Default RE: Horn Help Needed.
You have checked the fuse for the horn and cig lighter?
I think the horn is under the driver's headlight.
If you apply 12 vfolts directly to the horn and
it does not blast, just replace the horn.
Keep the relay for later.
How difficult was it to get off the wheel skin?
I need to fix my horn button.
Old Jun 14, 2007 | 08:39 PM
scarslilpyro
ORIGINAL: corvetteguy
Haven't checked the fuse.
And I am talking about a brand new, never used horn you buy at an auto parts store, this is what I have. http://img503.imageshack.us/img503/8623/dscn1725lt8.jpg
the wheel skin comes off very easy, it's just 3 plastic prongs
Old Jun 15, 2007 | 08:48 AM
corvetteguy
If you cig lighter works then there is power
to the horn.
I would just locate the horn and change out the
horn with the new one.
Connect neg terminal to the ground mounting
bracket and old horn wire to the new 12 volt terminal.
Usually the horn problem is the wheel button. In
my case the button is shorted and the horn starts blasting
when I park the car by itself.
Don't be surprised if the new horn sounds a little anemic.
George
Old Jun 15, 2007 | 08:52 AM
scarslilpyro
to the horn.
George
what do you mean by anemic? its one of those dual tone horns, very loud.
Old Jun 22, 2007 | 04:41 PM
scarslilpyro
Was taking pictures of what I believe is the stock amp, still need to find out, and figured I would take some of the horn button.
It looks blue because of my carport :s
http://img518.imageshack.us/img518/2650/dscn1755yy4.jpg
Hope this helps.
[IMG]local://upfiles/67551/FC262663B89D4721BA083C7A9CC1B56B.jpg[/IMG]
[IMG]local://upfiles/67551/74386B715C164AD1B850D5F40978CC70.jpg[/IMG]
[IMG]local://upfiles/67551/60C5CB6BCA6042E5BB08D904428A49C9.jpg[/IMG]
[IMG]local://upfiles/67551/8B0A883A6979475E8E4C0F2FD8E31EF0.jpg[/IMG]
[IMG]local://upfiles/67551/4CB59F8D78474F4BBC8C4FF842F0C75B.jpg[/IMG]
Old Jun 23, 2007 | 09:54 PM
scarslilpyro
-delete-
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
rocket22
Aug 28, 2015 07:08 PM
jesse1125
AmericanMuscle.com
Aug 26, 2015 02:34 PM
