stereo question
Old Sep 1, 2003 | 03:59 AM
burley's Avatar
burley
Default stereo question
just bought a 91 LX,anyone familiar with the wiring that could help me out? ive done many installs,all i need to know is which is my ground,
sorry for the repeat post. <edited><editID>burley</editID><editDate>37865.0843634259</editDate></edited>
Old Sep 1, 2003 | 04:37 AM
tripsevn7's Avatar
tripsevn7
Moderating with Angels
put a screw into the metal behind radio and add a stand alone ground... trust me its better that way.. the factory ground won't do well</P>
Old Sep 2, 2003 | 01:50 AM
67aquafastback's Avatar
67aquafastback
Whats wrong with the factory ground?
Old Sep 2, 2003 | 03:04 AM
tripsevn7's Avatar
tripsevn7
i was an installer for about 4 years and had a shop in hattiesburg, and we found on the older vehicles we could attain more stability throught the use of an isolated ground.. ie no engine, no white noise.. i believe on a meter you would see a drop of like 1.25 volts on the factory ground where as you could have a clean circuit witha self tapping screw into the metal in about the same time.
Old Sep 2, 2003 | 06:11 AM
n2o44's Avatar
n2o44
interesting , a vd of 1.25 ? the connection prob couldint handle the added current maybe ?
Old Sep 3, 2003 | 12:09 AM
tripsevn7's Avatar
tripsevn7
a factory radio puts out maybe 6 to 10 watts and pulls less current.. aftermarket radios rated a 45x4 have a continuous of about 14 to 16 pending of the voltage of the car.. some cars have 11 volts running threw them while others are around 15 ie a lax voltage regulator. the factory ground has a long run to it which tends to get weaker over length. just a handy tip to think of if you by some chance end up with a little whine in your system, checked your amp grounds and are lost, reground the radio
Old Sep 3, 2003 | 12:14 AM
frostymug's Avatar
frostymug
the fox bodies are known to produce quite a bit of alternator whine when the stock ground is used. I usually used a ground strap on mine or just let the stereo chassis ground to the dash mount.
Old Sep 3, 2003 | 01:20 AM
vfast's Avatar
vfast
I ♥ Acer
I like the handle *L*<img border="0" src=smileys/smiley17.gif border="0">
Old Sep 4, 2003 | 10:57 PM
Kidrosey's Avatar
Kidrosey
Also if you have any additional equipment such as amps, EQs, and/or crossovers it is best to ground everything to the same ground
jrrhd73must
Oct 2, 2015 09:17 PM
vbonina
Sep 22, 2015 08:31 AM
Ford_Dude
Sep 15, 2015 03:25 PM
TimeLord101
Sep 4, 2015 09:27 AM
movielover40
Aug 27, 2015 10:13 PM
