control arms question
Old Jan 6, 2005 | 11:46 PM
UT04GT's Avatar
UT04GT
Default control arms question
everyone seems to say to get lower control arms to reduce wheel hop, how worthwhile and cost effective are upper control arms? I know about -> <- that much about suspensions so any help is appreciated
Old Jan 7, 2005 | 12:56 AM
import slayer's Avatar
import slayer
Default RE: control arms question
I've always heard that the uppers are not as important as the lowers and it's better to just replace the bushings in the uppers with the stock bushings and not poly bushings because of possible suspension bind.
If you want to do anything with the uppers, I would just have them boxed and have new bushings installed.
Old Jan 7, 2005 | 01:01 AM
Mustangous's Avatar
Mustangous
with going throught that much trouble just replace them and call it a day....there not that expensive.
Old Jan 7, 2005 | 01:08 AM
import slayer
ORIGINAL: Mustangous
Yeah...to hell with any suspension bind you might get by doing that
Old Jan 7, 2005 | 01:16 AM
fastmustangs1's Avatar
fastmustangs1
They are not expensive, but however replacing the uppers will bind leading to other suspension problems like torque boxes.
Just leave the stock ones in but replace the lowers. I went with MM they are the best on the market.
If anything if you have the money convert to a 3-link rear with a torque arm and panhard bar. That is next for me.
Matt
Old Jan 11, 2005 | 04:10 AM
devinsteen's Avatar
devinsteen
I think the uppers help side to side movement which will allow you get staighter launches.
Old Jan 11, 2005 | 01:49 PM
RollinThunder's Avatar
RollinThunder
ORIGINAL: fastmustangs1
Matt
whats a 3-link rear w/ torque arm and panhard bar??...where can I read up on them and look at the parts?
Old Jan 11, 2005 | 01:56 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
I did both of mine and they are awsome. The uppers prevent roll of the chassis.
Old Jan 11, 2005 | 02:06 PM
RollinThunder
ORIGINAL: jdaniel
do u think the upper c/a's help u hook up better?...or is that just w/ the lower c/a's
Old Jan 11, 2005 | 03:47 PM
luckythirteen13's Avatar
luckythirteen13
i think just about anything you do to the stock suspension will help you launch better. the stock stuff isnt the greatest
