is high miles a problem???
Old Jan 8, 2005 | 07:11 AM
kazandlee's Avatar
kazandlee
Default is high miles a problem???
Hi,
Still looking for a mustang to import to the u.k, have seen quite a few v6 with high miles, around 50,000 to 70,000 miles, can anyone tell me roughly how many miles a v6's engine and tranmission, auto and manual are good for?
Old Jan 8, 2005 | 07:19 AM
Dan04COBRA's Avatar
Dan04COBRA
Default RE: is high miles a problem???
They could be good for only 10,000 miles from the factory depending on how it's driven and taken care of.
Figuring you found a well maintained car that was driven by a old lady, 140-160k isn't unusual before it needs a major overhaul.
Old Jan 8, 2005 | 10:19 AM
vfast's Avatar
vfast
I ♥ Acer
there is no actauly way to tell ya..buy on ang 100k is no problem,if well taken care of I don't see a problem with getting 150k+..way a v6? your gas prices?
Old Jan 8, 2005 | 11:40 AM
DaGGer's Avatar
DaGGer
well if you get a vehical that has 150,000 or around there i mean if it was well taken care of then its probably ok but buying it could lead to problems because it is an old engine...it probably wasn't beaten on which is why its still alive but engines have wear(SP) over time and they need to have certain things done....buying something with 100,000 isn't bad given hows its driven...so buying a car with lower miles is better in most cases but buying one with higher miles isn't always bad
Old Jan 8, 2005 | 02:21 PM
import slayer's Avatar
import slayer
It depends on how those miles were put on. If it's a lot of highway miles then 100K+ isn't as bad as a 100K mile car that was mostlydriven in town.
Also depends on the previous owner. I would hesitate to buy a mustang from some teenager.
It would be nice to find one that a little old lady owned and only drove to church on Sundays...LOL
Old Jan 8, 2005 | 02:26 PM
fast83gt's Avatar
fast83gt
ORIGINAL: import slayer
The church parkinglot is full of stangs every sunday
Old Jan 8, 2005 | 04:20 PM
e40water's Avatar
e40water
my friends dad has a mustang from 79 stang 2.8L V6, the car has 450,000 km's all the oil changes have been done 5,000k each time, Only major work has been done was timing chains / upper and lower gaskets / water pump / fuel pump. Otherwise the engine runs very well, Not blow by on the exhaust.
Old Jan 8, 2005 | 04:41 PM
vfast's Avatar
vfast
I ♥ Acer
well the lil ole lady I would worry as well*L*
Old Jan 9, 2005 | 02:24 PM
roundman's Avatar
roundman
ORIGINAL: kazandlee
Hi,
I would be more concerned with the condition of the body and chassis than I would the engine if I was going to import one from the USA to Britain. Avoid used cars from the northern states since they get lots of snow and ice and used lots of salt on the roads which attacks the car bodies and rots them out badly. try to find one from down south of Virginia or from the southwest where they don't get all the snow and the road salt problems. the engine and tranny can always be rebuilt fairly easily, but not the body or chaissis.
Old Jan 9, 2005 | 03:39 PM
DaGGer's Avatar
DaGGer
lol..he is right...if you need a picture i can put one on here to show you what happens to a mustang in the north if someone doesn't take care of the car...i really will put a picture up here just to show you how bad it really can be
