Pinging problem
Old Jul 3, 2007 | 04:10 PM
Dex's Avatar
Dex
Default Pinging problem
Ok my car started pinging when it got really hot outside. It only pings for a second around 2k RPM's. I can write down info and send it to the tuner but right now my schedule is packed and I cant go drive around to get the info i need. Lets get the no brainer questions outta the way by saying i run 91 octane (utah), 39# fuel injectors, etc...
there was 10% timing but i changed to to 15% to see if it would help with the knocking. didnt work....im wondering if there is a easy fix just for the week like trying a octane booster or something. Or if there is something i can tweak on the tuner (diablo)
Old Jul 3, 2007 | 04:44 PM
Blckstng93's Avatar
Blckstng93
Default RE: Pinging problem
Usually when you add more timing the engine can start to ping/knock no matter what. There is a limit. Your plugs also need to be the correct heat range.
With a tuner installed however it may just need tuned like you said. I dont know how to work them things but im sure you need the right plugs and all for it to all work together properly. Unfortunately i dont know tuners so thats as much as i can help with.
When in doubt call up the manufacturer, they should be able to answer anything about thier products.
Old Jul 3, 2007 | 04:47 PM
P Zero's Avatar
P Zero
So why dont you run 93? or 94? Or maybe go down to your local race track buy 5 gallons of racing gas and dilute it down with 93? You also need to back the timing off, giving more timing will increase your pinging.
-P.
Old Jul 3, 2007 | 05:00 PM
Derf00's Avatar
Derf00
Gentleman's Relish
why are you double posting? You already got your answer in the other thread. Retard the timing.
Old Jul 4, 2007 | 06:53 PM
Dex's Avatar
Dex
cuz this was the general forum so other mustang guys could answer. i dont go in the 5.0 threads so i posted in the 2005+ and this one. When the car was tuned it was fine and another tuner added 10% timing but its just now pinging because its gotten hotter. im wondering if i put it at 5 or 0 if it would help. If it doesnt then its probably the throttle timing
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
