piston rings
Old Jul 3, 2007 | 09:52 PM
eep4life's Avatar
eep4life
Default piston rings
any one know how or where i can go to learn how to install new piston rings?
Old Jul 4, 2007 | 03:32 PM
Chopper's Avatar
Chopper
Default RE: piston rings
It's not a hard thing to do so here's the procedure.
Take each ring,one at a time,and using a piston,shove it squarely into the cylinder it will be running in.
Use a feeler guage to measure the end gap of the ring.
If the end gap is correct I install the ring on the piston that will be used in that cylinder so I don't get it mixed up with the others.
If the end gap isn't correct (it usually isn't) you need to file the end of the ring until it is.Be carefull,sometimes you don't need to take much off.Once it's gone you can't put it back.You might do a trial run with one of the old rings to see how fast the file takes material off.Too much gap gives you lots of blow-by and high oil consumption.[:'(]Too little and you get ruined cylinder walls and /or broken rings.[:@]
Do this twenty three more times and you're done.
Old Jul 4, 2007 | 03:42 PM
Blckstng93's Avatar
Blckstng93
Get a ring installer for when youre ready to put them on the piston. Some spread the rings by hand but you risk breaking the rings. Some can do it, some cant. Get an installer. Spreader, whatever you want to call them.
poke68
Dec 16, 2025 03:36 PM
uberstang1
Dec 7, 2017 07:10 AM
Dathan
Oct 5, 2015 05:52 AM
DJ Piner
Sep 30, 2015 03:03 PM
degner122
Sep 16, 2015 07:09 AM
