problems
Old Jan 14, 2005 | 02:29 PM
wazu61's Avatar
wazu61
Default problems
i have a 93 5.0 lx and i cant figure out what is wrong. when i floor it it seems to die and then it will give it a little bit of gas and then go back to almost stalling. i have replaced the erg valve and gasket. put an h pipe system in it, new plugs, wires, and cap and royor, new fuel pump and i still cant get it. i think it might be the fuel pressure regulator or the injectors. andone that can help me, please do so. thanks
Old Jan 14, 2005 | 04:01 PM
89stanglx's Avatar
89stanglx
Default RE: problems
You need to change your fuel filter if you havent already.
Old Jan 14, 2005 | 04:21 PM
Pacman's Avatar
Pacman
sounds like the way my truck was. my tps (throttle positioning sensor) was the culprit. pull your codes man. easiest way. no point in changing things that you dont have to.
Old Jan 15, 2005 | 12:05 AM
mysticsvtcobra96's Avatar
mysticsvtcobra96
could have water in your fuel system (tank) or your injectors might be cloged up
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
