aviation fuel?
Old Jul 8, 2007 | 03:13 AM
347stang's Avatar
347stang
Default aviation fuel?
I have been looking at some fuel posts and saw aviation fuel is being used in place of race fuel. It does not seem to be crazy expensive, but is it safe for a car? I was going to drop the boost on my stang but after seeing this I may just do aviation fuel instead if it is safe. Can it be mixed with regular 91 oct unleaded fuel?
Old Jul 8, 2007 | 11:06 AM
Chopper's Avatar
Chopper
Default RE: aviation fuel?
Avgas still contains lead so it's not safe for catalytic convertor orO2 sensor equipped vehicles.
100LL stands for one hundred octane low lead.
Old Jul 8, 2007 | 11:59 AM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
This comes up way too often. Avation fuel is not in a good substitute for higher octane race gas in a an automobile application. Av-gas is designed for relitivly low rpm engines that operate at high altitudes. things like specific gravity are not the same. I am sure people will arguee this point with me and that's fine, but I would not use it in my car. Tome it's just 1960's thinking, because they used it "back in the day".
Old Jul 8, 2007 | 12:13 PM
samseed101's Avatar
samseed101
If you're concerned with boost and detonation, then spend $200 and buy a water / methanol injection kit. hen you can spray windshield washer fluid into the intake to greatly lower temps and to slightly increase octane. It's only used when you need it (under boost.) And washer fluid is pretty damned cheap.
Old Jul 8, 2007 | 02:20 PM
347stang's Avatar
347stang
ORIGINAL: samseed101
I just found this, is this what you are talking about?
http://www.alcohol-injection.com/wat...jection-8.html
Also does it automaticaly spray when a set psi is hit or do you decide when to spray it?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
mrappe
Sep 26, 2015 10:16 AM
