any modifications needed for tb+plenum?
Old Jan 15, 2005 | 02:26 PM
timi's Avatar
timi
Default any modifications needed for tb+plenum?
hi,
i was wondering if there is anything that has to be done when installing the tb and plenum and if the car is gonna need to be tuned more.
thanks
timi
Old Jan 15, 2005 | 02:28 PM
RollinThunder's Avatar
RollinThunder
Default RE: any modifications needed for tb+plenum?
yes ur car is gonna have to b tuned...ur a/f ratio is gonna b farked up if u dont and ur car wont b running as well as it could b...when I had my t/b and upper intake installed the first pull on the dyno only produced 158rwhp and my car was running soo lean the guy was surprised it was even running...after the tune the results r in my sig
Old Jan 15, 2005 | 05:39 PM
87mustang347's Avatar
87mustang347
what years ur car? if its a 5.0 u wont need a tune. ive had alot of people bolt on intakes and what not with out tunes and there fine. u mite want to invest in a fuel pressure regulator tho
Old Jan 15, 2005 | 09:51 PM
roundman's Avatar
roundman
if it's a 5.0 just disconnect the negative battery cable for at least 10 minutes to clear the KAM in the ECU. and set the TPS output voltage to 0.98 volts with the throttle closed and key on but engine off and you should be fine.
Old Jan 16, 2005 | 03:06 AM
ONE BAD GT's Avatar
ONE BAD GT
Whoa RollinThunder picked up 113 rwhp with just a tune. It must be a diesel.
Old Jan 16, 2005 | 12:00 PM
timi's Avatar
timi
it's a 2000
timi
Old Jan 16, 2005 | 12:19 PM
ONE BAD GT's Avatar
ONE BAD GT
You might want to get a tuner. Im gonna get a tune after i finish my mods.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
defarmer
Aug 13, 2015 06:40 AM
Danwiel
Aug 11, 2015 06:49 AM
