302 wants to shift again???
Old Jul 14, 2007 | 06:55 AM
tnsn71's Avatar
tnsn71
Default 302 wants to shift again???
i have 67 stang with 302 in it, the tranny is a c4. the tranny shift into second gear to fast then into thrid gear to fast, then it sounds and feels like the engine wants too shift again?? it sounds like its whining out and reving to high, like it needs to shift again. can any help me? i don't know if tranny needs adjusting or what. thanks
Old Jul 14, 2007 | 08:21 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Default RE: 302 wants to shift again???
Well first off, a C4 is only a 3speed...so its goin to wind out 3rd gear because it doesnt have another one to go into. Is it shifting too fast under heavy throttle? Adjust the kickdown cable and you should be able to delay the shift.
Old Jul 14, 2007 | 08:49 AM
tnsn71's Avatar
tnsn71
thanks, but my problems is when its in third gear it sounds and feels like it wants to shift again. thats what i meant, sorry if there was some confusion.. it whines out in third gear. any suggestions?
Old Jul 14, 2007 | 10:19 AM
koesterca1's Avatar
koesterca1
Of course it sounds like it wants to shift again, but a C4 only has 3 gears. As previously mentioned it doesnt have anymore gears to shift into so the rpms will continue to climb. With my 289/C4 combo with 3.55 gears on the highway im running 3000 rpms. Thats the reason why some guys swap AODs into C4 equippedcars.
Old Jul 14, 2007 | 06:45 PM
tnsn71's Avatar
tnsn71
yes, i understand it has only 3 gears but, this thing sounds like its reving at 6000 rpms not 3000. thats what i mean when i say it wants to shift again. and i'm only doing about 40 mph
Old Jul 15, 2007 | 06:09 AM
corvetteguy's Avatar
corvetteguy
If you have a rear end that is used for the track
you will have the same problem.
If you believe your speed and rpms
what are the RPMs and MPH in each geer?
Old Jul 15, 2007 | 06:28 AM
Gary H's Avatar
Gary H
Trans might be slipping. Bands adjusted or it may need to be rebuilt.
bradleyb
Nov 27, 2015 07:50 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
