pinion snubber question
Old Jan 21, 2005 | 06:30 PM
luckythirteen13's Avatar
luckythirteen13
Default pinion snubber question
i put my snubber in today and noticed its really close to that plate on the top of the pinion. it is set as high as it can go so adjusting it wont do anything. i was just wondering if its supposed to be that close. also, could i remember that plate on the top of the pinion for more room and then lower the snubber down when i get to the track?
what is that thing that hangs from the bottom of the pinion?
i also attached a picture of one of my new upper arms installed. they are so much nicer then the piece of $h!t stock arms
Old Jan 22, 2005 | 02:29 AM
Obsol3te's Avatar
Obsol3te
Default RE: pinion snubber question
Can't remember exactly, but there should be recommendations in your short list of directions for the snubber.
Think it was 1/2 for Non-Track use. and 1/4 for track use
If you do happen to need more space you have to cut some of the snubber rubber down or the metal shaft.
Old Jan 22, 2005 | 02:35 AM
luckythirteen13
well its about a half inch now so ill leave it as is. i think though, im going to pull it down and wrap the lower part of the snubber (the part that moves up and down) with a little bit of electrical tape because its loose and when i go over bumps, i can hear it rattle down there.
http://www.koolpages.com/potatohell/trucks.html at the bottom are a few more pics i took today
Old Jan 22, 2005 | 05:22 PM
Obsol3te's Avatar
Obsol3te
I love that rattle for some reason
I can hear it smash when I shift through the gears fast
Well im just stupid, but I think it sounds kinda cool.
baddog671
Jul 26, 2016 01:20 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
KingRando
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
