horrible squeaking
Old Jan 23, 2005 | 12:49 AM
stock_95gt's Avatar
stock_95gt
Default horrible squeaking
Just recently (about 3 days ago) my car started acting up.
I've narrowed it down to the front right suspension, shocks/springs, etc area.
Any time I go over rough roads (just about everywhere) there's a horrible squeaking/creaking sound coming from the shocks or some part of the car..
My initial guess is maybe there's dirt that got up in the suspension, causing it to squeak?
Any ideas?
Old Jan 23, 2005 | 12:55 AM
import slayer's Avatar
import slayer
Default RE: horrible squeaking
Try having a buddy push down on the front of the car several times while you listen near the fenderwell to see where the noise might be coming from.
It sounds like a bushing noise from somewhere.
Old Jan 23, 2005 | 01:58 AM
chriscindy6369's Avatar
chriscindy6369
The Rubbers Rings under each coil spring. they could be bad. They make that same type of noise your talking about when they go bad....
Old Jan 23, 2005 | 02:07 AM
stock_95gt's Avatar
stock_95gt
How can I tell if the rubber rings and/or bushings, etc are bad?
Would they look all torn and ripped apart from excessive wear?
Where do you suggest going to purchase new ones? NAPA, Autozone?
And roughly how much do you think they'll cost?
thanks
Old Jan 23, 2005 | 12:01 PM
vfast's Avatar
vfast
I ♥ Acer
well usually wear the isolators are gone the car seems lower?...I would spray the spring area with wd-40 to see if it quits if not go the the a-arms and spray the bushings..then more on..
Old Jan 23, 2005 | 10:23 PM
fastmustangs1's Avatar
fastmustangs1
It sounds like the front struts could be going out. Usually before the struts go out they will begin to make a creaking noise.
It also could be a bushing as well. You probably still have the stock rubber ones still in there. The urethane ones will also
make a squeeking noise too.
Matt[:'(][:'(][:'(][][][&o]
Old Jan 25, 2005 | 08:04 PM
stock_95gt's Avatar
stock_95gt
quick update.
I took off the front wheels, and the bushings are fine. I really do think its the suspension (struts?) .. but I have no idea how to actually figure that out.
I guess I'll end up taking it to the place which did my steering column and see what they come up with and get an estimate.
Old Feb 2, 2005 | 07:22 AM
Shaggy's Avatar
Shaggy
im having the same problem with my 03. i honsetly dont think that my shocks or anyhting have worn out but like stock said, when i go over bumps and rough roads i hear a squeak from the front, usualy passenger side. WTF?!?! lol.
Old Feb 2, 2005 | 12:58 PM
tyybo's Avatar
tyybo
IM havin the exact same problem and im stumped. all my noise is comin from the back. if a heavy person sits in back it will squeak. and when i take off or hit bumps it squeaks.. sooo damn annoying. All my shocks/struts/control arms are spanking new too
Old Feb 2, 2005 | 03:26 PM
sanitarium16's Avatar
sanitarium16
Have you check the tie rod ends? I had a similar problem with my car and i needed the tie rod ends replaced. All my squeaking then went away.
woodvette
Oct 30, 2015 01:14 PM
GLOCKer
Sep 28, 2015 07:36 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
TimeLord101
Sep 4, 2015 09:27 AM
Sandmanbjj
Aug 21, 2015 12:38 PM
