Ticking due to Distributer?
Old Jul 25, 2007 | 07:29 PM
TommyGT's Avatar
TommyGT
Default Ticking due to Distributer?
I got a 1988 GT 302 engine just rebuilt. I hear a loud metalic ticking sound comming from the engine. I think it might be a noisy lifter. The ticking does speed up when the engine is reved. Someone told me that if the distributer was put in one tooth out it could cause this sound. Is this possible? And can i just replace the lifters w/o replacing the cam?
Old Jul 25, 2007 | 08:51 PM
1991LX5.0's Avatar
1991LX5.0
Default RE: Ticking due to Distributer?
Yes it possible, the distributor could have been stabbed one tooth off and be causing the timing to be way off and could be detonating but i dont think it would be making that sound at idle. If you have a timing light you can check it. It is most likley a collapsed lifter or improperly adjusted rocker. And yes you can replace the lifters without removing the cam
Old Jul 25, 2007 | 10:51 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Having the distributor off by a tooth won't cause ticking by itself.
It could definitely be a lifter, but it could also be a worn rocker arm (pivot, valve, or push rod area).
TCStangerv6
Oct 11, 2015 05:57 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
wraith777
Sep 28, 2015 10:49 AM
Sixer4Life
Sep 28, 2015 07:05 AM
Sep 24, 2015 09:18 PM
