sparkplugs and plug wires
Old Jan 28, 2005 | 05:34 PM
link1235jeff's Avatar
link1235jeff
Default sparkplugs and plug wires
i was wondering what plugs and wire to get for this might be buying a 92 gt with 168000 miles 5 speed all stock and spend under 60 or 70 for plugs and wires
Old Jan 28, 2005 | 05:36 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: sparkplugs and plug wires
id get the msd super conductor wires. $70 i think. and some autolite plugs. but if the car is stock, id get something that will make more of a difference then wires
Old Jan 28, 2005 | 07:42 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
for 70 bucks go cai and a nice dinner
Old Jan 29, 2005 | 12:56 AM
Dan04COBRA's Avatar
Dan04COBRA
ORIGINAL: AtlanticBlue99
...I'd assume with 168k miles he needs a tune up more than a CAI.
Old Jan 29, 2005 | 01:16 PM
vfast's Avatar
vfast
I ♥ Acer
really
get a dist cap with brass terminals,rotor button,,set of low ohm wires and some boush plat plugs..then when $$$$ permits install a MSD 6at
Old Jan 30, 2005 | 05:48 PM
link1235jeff
are Autolite Ignition 25 any good
Old Jan 30, 2005 | 06:11 PM
link1235jeff
between these two spark plug wires witch ones
Autolite Ignition 86259
Spark Plug Wire Set: Pro-Fit
Matches original equipment for trouble-free installation
Pre-greased premium silicone boots prevent corrosion at terminal-spark plug connections
Over-sized wire diameter provides protection from harsh engine contaminants
Heat resistant Insulast jacket maintains performance at high temperatures and prevents voltage loss
Designed to meet the needs of professional installers
Lifetime Limited Warranty
or
Accel 4056
Spark Plug Wire Set: 8mm SuperStock; Graphite; Yellow
Custom Fit Super Stock Spark Plug Wire Set: 8mm; Copper Wire Core; Black;
1 Year Replacement Warranty
Old Jan 31, 2005 | 12:16 PM
link1235jeff
so what do yall think
Old Jan 31, 2005 | 06:09 PM
AtlanticBlue99
I ♥ Acer
autolite dbl platinum plugs last forever, id go with them ofr plugs, and the wires, id go with autlite pro fits.
Old Feb 1, 2005 | 06:28 PM
vfast's Avatar
vfast
I ♥ Acer
nethier....look on ebay and atleast get a set of split fire wires....
