Car seems higher after mods
Old Jan 29, 2005 | 07:45 AM
ONE BAD GT's Avatar
ONE BAD GT
Default Car seems higher after mods
I put on lower control arms from granatelli and also tokico shocks. Now my car is just a bit higher in the back then it was before i did these mods. Is this normal? What is making it higher?
Old Jan 29, 2005 | 02:07 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: Car seems higher after mods
Yeah, it will take a while to settle in. Don't worry, s'all good man.
Old Jan 29, 2005 | 08:27 PM
ONE BAD GT's Avatar
ONE BAD GT
did you notice a difference if you took out the sway bar and quads?
Old Jan 29, 2005 | 11:37 PM
code3GT's Avatar
code3GT
Mustang Nazi
I left my sway bar and quads. I am thinking about taking off my quads, just haven't decided yet.
Old Jan 30, 2005 | 01:35 AM
luckythirteen13's Avatar
luckythirteen13
if you have lowers, quads are dead weight. not so sure id take the swaybar out though
Old Jan 30, 2005 | 02:49 AM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: luckythirteen13
I thought it was only okay to remove the quad shocks if you replace the upper CA's?????????????????
Old Jan 30, 2005 | 05:04 PM
Jimmz's Avatar
Jimmz
Whoa!!!! man it looks like you got a 4x4!!! I would ask a proffessional about this, maybe it was installed wrong, or it didnt have time to settle. Get some heavy people to sit in the back and see if it helps lol. thats what I'd do.
Old Jan 30, 2005 | 06:43 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
ORIGINAL: code3GT
yea give it a day or so and it will be back to normal
yeppers
ORIGINAL: code3GT
no its the lowers that need to be replaced for that, not the uppers. The uppers mainly help locate the axle during side to side movement, the lowers can deflect when alot of pressure is on them, which is why the quads are there - to keep the bouncing of the rear cause by deflection to a minimum. With aftermarket lowers their is no flexing / deflection - therefore no need for the quads. Them + their upper brackets weigh like 10 lbs so its worth it to remove em
Old Jan 30, 2005 | 11:54 PM
ONE BAD GT's Avatar
ONE BAD GT
That sig pic was when i first got the car. Thats the only pic I got. I wonder if someone would be willing to photochop it for me.
msavoia23
12
Jul 7, 2018 12:08 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
dragman72
Aug 9, 2015 12:54 AM
