Injectors?
Old Aug 26, 2007 | 09:54 PM
5.0buildnherup's Avatar
5.0buildnherup
Default Injectors?
Hey guy's i got a layoff coming up this october like first week for two weeks. so i plan on building up my engine a little bit since i will have the time. im hopefully going with a trick flow track and heat intake/plentom but im not sure what fuel injectors would i run . this is not a mustang im workn on its my 89 mark vii it has the 5.0ho 302 in it though. thanks guys. i don't know pretty much nothing bout injectors although been doing research bout it slowly.
Old Aug 28, 2007 | 09:19 PM
88_LX's Avatar
88_LX
Default RE: Injectors?
ford racings 42s will allow for future upgrades and if you change your maf and stuff you can get a bigger one because you have more fuel. if you do a fuel pump and injectors you are just paving the way for fi in the future
Old Aug 28, 2007 | 09:50 PM
1991LX5.0's Avatar
1991LX5.0
ORIGINAL: 88_LX
whoa 42lb injectors are WAY too big. From what i understand this will be a stock H.O motor with some bolt ons and an upper/lower intake. The stock 19lb injectors are fine for that set up. If you plan on doing a heads/cam upgrade in the future then i would go with 24/30lb injectors depending on what you plan
Old Aug 29, 2007 | 03:35 AM
w8less's Avatar
w8less
24's will be fine. get an adjustable fuel pressure regulator if you done have one already. also be sure to get a matching Mass air sensor calibrated for the new injectors
GimpyHSHS
19
Dec 19, 2023 01:12 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
MacSerio
Sep 27, 2015 01:05 PM
mltdwn12
Sep 23, 2015 08:54 AM
