oil pan gasket replacement
Old Aug 31, 2007 | 04:30 PM
90LX5OH's Avatar
90LX5OH
Default oil pan gasket replacement
hey guys just joined and i'm needing some help. just got my third fox, a 1990 dark metallic titanium 5 speed coupe, and its got some leakage issues. anyone got any advice about putting on a new oil pan gasket? any advice or help would be great.
Old Sep 1, 2007 | 04:55 AM
5.0fuz's Avatar
5.0fuz
Default RE: oil pan gasket replacement
get a book
Old Sep 1, 2007 | 12:01 PM
Colorado_Mustang's Avatar
Colorado_Mustang
You'll want to jack up the engine (remove the 2 bolts for the engine mounts) to gain clearance. You'll likely have to drop the oil pickup tube to get the pan all the way out, which isn't hard, but is tedious. Although you can definitely change the gasket with the engine in the car, you're more likely to have leaks and it may simply be easier to pull the engine out to make sure you get the gasket in properly. Plus, it's likely other gaskets are deteriorating.
Also, make sure the pan bolts are snugged down properly before deciding to change the gasket.
Old Sep 1, 2007 | 12:18 PM
5.0fuz's Avatar
5.0fuz
I just read my comment again and it kinda seems ignorant, I didn't mean it like that, i just meant get a book as my advice, will always come in handy, and lay everything out pretty much frame by frame, torque specs everything
Old Sep 1, 2007 | 12:47 PM
67mustang302's Avatar
67mustang302
Yes, definately get a book, or 3. Shop manuals are great resourses. Also I'd recommend using Fel Pro's 1 piece oil pan gasket
Old Sep 2, 2007 | 12:10 PM
tinman's Avatar
tinman
+1000
Nick Oliver
Oct 17, 2018 04:22 AM
StalkerGT
Sep 25, 2015 02:41 PM
zanemoseley
Sep 6, 2015 12:58 PM
Emblazoned
Sep 3, 2015 10:45 PM
cbird1177711
Sep 3, 2015 08:43 PM
