removal of window
Old Feb 11, 2005 | 08:28 PM
Vizaracer's Avatar
Vizaracer
Default removal of window
i have a friend that needs to remove his driver side door window of a 2001 mustang Gt rag top. what all is needed to remove the window?
Old Feb 11, 2005 | 08:57 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: removal of window
a hammer
Old Feb 11, 2005 | 09:59 PM
Vizaracer's Avatar
Vizaracer
[sm=goodidea.gif]
well... lets repraise this.... while keeping the window in 1 piece....
Old Feb 12, 2005 | 02:53 PM
roundman's Avatar
roundman
it's best to get a door clip removal tool from the local auto parts store so you don't break the clips while removing the interior door panel to get access to the window. use this tool around the edges of the door panel to pop the panel clips loose from the holes in the door frame after removing the bolts in the arm rest. you also need to remove the covers for any switches mounted in the door and unplug the wiring connectors too. once the entire door panel is loose, remove it and set it aside. there is usually a piece of oiled paper covering the door frame which you then carefully loosen and remove also. this will expose the large openings through which you can get access to the bolts holding the window to the regulator framework so you can remove the window.
Old Feb 12, 2005 | 03:18 PM
fast83gt's Avatar
fast83gt
Why don't you email the guy that sold it on ebay and ask hime what kind of hood is is?
Old Feb 12, 2005 | 07:25 PM
Pacman's Avatar
Pacman
ORIGINAL: fast83gt
huh
Old Feb 12, 2005 | 08:35 PM
Vizaracer's Avatar
Vizaracer
ORIGINAL: Pacman
ORIGINAL: fast83gt
huh
ditto.
Old Feb 12, 2005 | 08:50 PM
2kgt357m's Avatar
2kgt357m
the newer stangs do not have the old style clips that hold the door pannel on. You pop out the hand hole deal remove 2 screws and push up on the door panel.
Viza was asking the question for me. I have the door panel off and the plastic backing, I just don't want to start removing all the tracks and other stuff I don't have too.
I have removed the top trim rails from the top of the door and removed the stops.
Do I have to remove all the tracks and motor or casn I get away with just remnoveing???????????????
Thanks for any and all help.
I thought about the hammer idea and I think it would work well.... LOL
Old Feb 12, 2005 | 09:52 PM
vfast's Avatar
vfast
I ♥ Acer
yeah hit it with a hammer and let the ins company pay to have it fixed..problem solved
Old Feb 12, 2005 | 10:31 PM
2kgt357m's Avatar
2kgt357m
not that easy my ins will not cover it.... I am trying to fix some damage my daughter did to the door which is not covered either. I don't want my rates to go up.
I will take it all apart if I have to it just seems like there has to be an easier way
