1 wheel drive????
Old Feb 16, 2005 | 10:50 AM
naty_M3's Avatar
naty_M3
Default 1 wheel drive????
A friend of mine says his '98 mustang conv. is 1 wheel drive... (that when he tries to make a burn-out only the right rear tire is rubbin') can someone please tell me the real story about the RWD of these cars?
PS- I dont know anything about these types of cars... Just trying to learn.
Thanx,
Naty ///M
Old Feb 16, 2005 | 11:48 AM
SilverGTV8's Avatar
SilverGTV8
Default RE: 1 wheel drive????
It doen't have a posi-rear end. It has a limited slip. You can do numerous things to make it posi. Pegleg burnouts are stupid.[8D]
Old Feb 16, 2005 | 01:11 PM
roundman's Avatar
roundman
ORIGINAL: naty_M3
Thanx,
Naty ///M
there are three types of rear differentials in use today: open type, positive traction type, and locked type. in the open type differential, only one wheel gets all the torque from the engine to drive the car forward, the right rear wheel.
in the positive traction type, the differential has various designs which provide torque to both the rear wheels under hard acceleration but still acts like an open differential when the car makes a turn by letting the outer wheel freewheel so it can turn easily. there are many types and names for positive traction differentials like Ford's Traction Lok, limited slip, Auburn, Eaton, and Detroit Locker.
in the locked type differential, there is no differential but instead a spool is used which connects both rear wheels to the ring gear at all times so both wheels get the same torque from the engine at all times. this type is a drag race only rear end which is not good for street use as the tires cannot freewheel in turn and this scrubs off the rubber tread in the tires over a short time.
an open differential can be modified to be a positive traction one with the addition of a posi-type differential housing being added to it.
Old Feb 16, 2005 | 01:13 PM
primetime5.0's Avatar
primetime5.0
sounds like the track loc went bad
Old Feb 16, 2005 | 04:09 PM
naty_M3's Avatar
naty_M3
thanx a million!
i can see what a moron he is... 1 wheel drive?? JA!
Old Feb 16, 2005 | 06:19 PM
fast83gt's Avatar
fast83gt
ORIGINAL: SilverGTV8
Posi is a chevy name for limited slip. Limited slip would let you do a two wheeled burnout.
Old Feb 16, 2005 | 07:43 PM
Aixtreme89's Avatar
Aixtreme89
Mabye your friend has a V-6 mustang. Which dont come stock with a limited slip. So thats what happens when you try a burn out. Nothings wrong with it, if thats the case.
Old Feb 16, 2005 | 08:37 PM
pipeliner's Avatar
pipeliner
Ask him if he wants to buy a traclok with 500 miles on it. I just took mine out and but in a true-trac
Old Feb 16, 2005 | 10:49 PM
DaGGer's Avatar
DaGGer
yea i know one wheel burn outs suck...but hey i can put some good amount of smoke with my one wheel...just really sucks though
Old Feb 20, 2005 | 02:50 AM
Ezrider's Avatar
Ezrider
ORIGINAL: roundman
ORIGINAL: naty_M3
Thanx,
Naty ///M
i may have read your post wrong and im not trying to step on your toes. basicly you are right, but an open diff will tranfer power to both wheels untill one brakes traction then all the power will transfer to the wheel with the least resistance thew the spider gears. posi traction uses cluch packs and alows one side to slip a little for making turns but both tires are still engauged. this is best for a street drivin car but in siuations where one tire has far less traction than the other the tire with the least resistance will get about 60% of the power and the tire with more traction will only get about 40% of the power.
