Electrical system 1984 GT
Old Sep 25, 2007 | 10:41 PM
Sumtoy#3's Avatar
Sumtoy#3
Default Electrical system 1984 GT
I am at my ropes end on this, I am hoping someone can help;
I have replaced the battery (new) its only pulling 11 volts, new 60 amp Alt., (sufficient for application) new voltage regulator, new starter switch and new battery cables all around.
Car would start with jump run fine, once turned off then would just click and not start. Once I replaced the starter swtich today the lights came on but in a split second it all went off. Now nothing comes on simply nothing.
Any suggestions.... I will check my fuses tomorrow in the daylight but they were fine before everything went out today.
I have had the new alt checked today and it is pulling the right amps.
Please help
Old Sep 26, 2007 | 02:35 AM
johnnyhou's Avatar
johnnyhou
Default RE: Electrical system 1984 GT
Hate to say it but it may be the terminals or cables themselves. Corrosion can eat away at the coper strands in you battery cable and cause the cable itself to fail even though the terminals are clean. Be sure to check the integrity of BOTH ends of BOTH cables.
Old Sep 26, 2007 | 09:30 AM
Gary H's Avatar
Gary H
Check the voltage drop of the battery when you try and start it. Just because the battery is new doesn't mean it's good. It shouldn't drop below 10. Which cables did you replace?
Old Sep 27, 2007 | 10:26 PM
Sumtoy#3's Avatar
Sumtoy#3
The battery was the problem its now fully charged and it starts and stays running. Thanks for the help. I also put new cables on double checking all the ends.
Old Sep 28, 2007 | 08:55 AM
Gary H's Avatar
Gary H
Cool.
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
