throwout bearing apps
Old Feb 18, 2005 | 05:17 PM
joes4_6's Avatar
joes4_6
Default throwout bearing apps
sup?i need help concerning clutch and throwout bearing applications for a 97 gt.i have a borg warner brute clutch in the box but its for an earlier year.does anyone know if at least the throwout bearing is interchangeable?i had a new clutch put in but not a great one and the bearing started makin noise after a week or two.some clutches are supposed to be good for 87 and up whereas others are separated into two groups for mod and 5.0 engines.i know the smart thing would be to just get a new clutch and put it in but thats an expensive option right now.should i take a chance pullin it apart to try the switch or no?
Old Feb 18, 2005 | 06:55 PM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: throwout bearing apps
When ever you change your clutch its always a good idea to put in a new pilot bearing (bushing) and throwout bearing while you have the transmission dropped. If the clutch goes bad chances are they are going to go bad pretty soon after. When changing clutchs you normally recommend it so the customer doesn't come back 500 miles later saying you messed there car up when its the throwout bearing going out. Hope you take this tip in mind next time you drop you transmission, it will save you some time.
6bangr
Feb 15, 2016 07:40 AM
KingRando
Oct 2, 2015 08:06 AM
Sep 30, 2015 12:39 PM
Offendant
Sep 23, 2015 07:21 PM
