Motor Mounts
Old Feb 21, 2005 | 12:38 AM
chriscindy6369's Avatar
chriscindy6369
Default Motor Mounts
Any of you all using Solid Motor mounts and tranny mount?
Old Feb 21, 2005 | 02:41 AM
bobby's Avatar
bobby
Default RE: Motor Mounts
not here
Old Feb 21, 2005 | 07:13 AM
primetime5.0's Avatar
primetime5.0
not here
wow another great post bobby, i think some peeps around here are using them, ive heard they give a rough ride
Old Feb 21, 2005 | 01:03 PM
roundman's Avatar
roundman
I'm using the solid motor mounts but not a solid tranny mount at the same time. Read somewhere you shouldn't run a solid tranny mount with solid motor mounts or you run the risk of tranny damage for some reason. Has something to do with chassis flex breaking the tranny case I think, not real sure.
Old Feb 21, 2005 | 02:35 PM
Acer2428's Avatar
Acer2428
Site Mod
I'm thinking about running poly mounts if/when I pull my motor.
Old Feb 21, 2005 | 02:46 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
not I, I dont want that rough of an idle with cams shaking the car all the time
Old Feb 21, 2005 | 06:49 PM
vfast's Avatar
vfast
I ♥ Acer
roundy you are correct on that as I have seen many of 2000.00 power glide trashed.....I would not use solid engine mounts on a street car....then main reason for these mounts is for better horsepower as you lose some hp due to the rubber mount cushoning horsepower transfer.......using a chain or adjustable rod bolted to the frame and head/block can accomplish close results
Old Feb 21, 2005 | 11:55 PM
95_GT_Stang's Avatar
95_GT_Stang
I think this is what your talking about vfast. jegs has a torque link that is removable for street drivin. its part#247-4010 if you wanna check it out
Old Feb 21, 2005 | 11:58 PM
C/Note's Avatar
C/Note
I ♥ Acer
ORIGINAL: chriscindy6369
i got them both...
Old Feb 22, 2005 | 12:04 AM
grabbem88's Avatar
grabbem88
i use solid,stock replacement for the tranny.....poly doesn't last long in the mid-west they crack reall bad..if driven in snow.
