NEED HELP BADLY
Old Feb 22, 2005 | 04:08 AM
bigdog101197's Avatar
bigdog101197
Default NEED HELP BADLY
I HAVE A 88 LX I PUT A TRICK FLOW INTAKE AND 24# INJECTORS AND A 75 MM THROTTLE BODY, ADJUSTABLE FUEL REGULATOR. AND WHEN I STARTED IT UP I GET ALMOST A WHITE SMOKE, BUT NOT THICK LIKE SMOKE. I PULLED THE INTAKE APART AND I HAVE FUEL POOLED ON THE INTAKE VALVES. I TRIED PUTTING THE STOCK FUEL REGULATOR BACK ON BUT ALL THAT DID WAS RUN BAD AT LOW RPM. WHAT CAN I DO TO TEST FOR WHAT IS WRONG. OR DID I OVER LOOK SOMETHING. I BACKED THE OTHER FUEL REGULATOR SCREW ALL THE WAY OUT BUT IT DIDNT HELP. I AM STUMPED. ANDY HELP WOULD BE GREAT THANKS ADAM
Old Feb 23, 2005 | 11:55 AM
Chopper's Avatar
Chopper
Default RE: NEED HELP BADLY
White smoke is usually steam.Did you have a coolant leak you didn't notice untill after you did the work on the car?Pressure test the system and see if it will hold pressure.As for the fuel on the valves maybe the injectors are too big???Try changing back to the original injectors.
Old Feb 23, 2005 | 11:55 PM
Master's Avatar
Master
what mods have you done to the car thus far to put the 24# injectors on?
Dathan
Oct 5, 2015 05:52 AM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
GLOCKer
Sep 28, 2015 07:36 AM
