n00b questions
Old Feb 24, 2005 | 02:18 AM
freefall86's Avatar
freefall86
Default n00b questions
I have a couple questions.
One being, I got a check engine light coming on. I got it checked, they told me it's the EGR valve. Is it an easy install? Until it's replaced will that have any effect on my HP or MPG at all?
I got new brakes recently as the others were trashed. They seem to squeal now even more then before, this is braking from almost any speed, it's a horrid noise. I talked to my dad about it as I am completely clueless and he said the person who put the brakes on may have just put cheap pads on. This may be true, but I find it ridiculous they would squeal that consistantly or that loudly. Is he right? or is he blowing smoke?
I was reading about removing the air silencer, does this make any difference on a V6?
Thanks!
Old Feb 24, 2005 | 07:14 PM
freefall86's Avatar
freefall86
Default RE: n00b questions
heeeeeeeeeeeeeeeelp! lol
Old Feb 24, 2005 | 09:38 PM
AtlanticBlue99's Avatar
AtlanticBlue99
I ♥ Acer
dont know
cheep pads or wet pads or grease on pads/rotor
slightly more intake noise, but a cai would be better performance wise- either way, air intakes give minimal gains with the stock throttle body. id suggest getting a new cold air intake kit and a good filter that is washable and reusable.
Old Feb 24, 2005 | 09:48 PM
Casper98GT's Avatar
Casper98GT
I ♥ Acer
I would really like the codes, because if its a P0401. Dont replace the EGR valve. lol. Its a waste of time, and money. And the CEL will stay on. And if it happens to be the EGR, which i have never replaced on a Stang, because they never needed them, then yes. Its easy install, and yeah it will hinder Gas milage slightly. But not so much Hp.
The brake problem, could be a new brake pad material. Also could have gotten something in there such as a rock against the backing plate. Also youre correct, someone could have put them on wrong. I would yank the 2 bolts on the caliper and remove the pads and check it out.
Old Feb 24, 2005 | 10:25 PM
thelast50ho's Avatar
thelast50ho
alot of time the more expencive brake bads make noise because the are made of a harder material that is desihned to last longer
Old Feb 25, 2005 | 01:20 AM
DaGGer's Avatar
DaGGer
do your brakes make the sound all the time when you drive...i mean after you drive for a while and the brakes have warmed up do they still make the noise
Old Feb 25, 2005 | 01:44 AM
freefall86's Avatar
freefall86
ORIGINAL: DaGGer
yea, it doesn't matter how long I've been driving, any time I brake they squeal.
they aren't brand new either, I know brand new brakes make the noise, that's not a noise like you hear when you brake with mine.
Old Feb 25, 2005 | 11:48 AM
dc_mann8's Avatar
dc_mann8
did u get new rotors too? isnt there some kind of coating on new rotors ur supposed to take off? if he didnt maybe this is causing it?
Old Feb 27, 2005 | 07:32 AM
mikev08826's Avatar
mikev08826
I ♥ Acer
what year/model??? Brake pads will always "squeak" a little.
Old Feb 27, 2005 | 02:57 PM
freefall86's Avatar
freefall86
ORIGINAL: mikev08826
'99 Mustang Coupe V6
This isn't a little squeak, lol,
