Would not start
Old Oct 23, 2007 | 08:02 AM
mels50's Avatar
mels50
Default Would not start
I have a ’90 lx Convertible. It has several mods and ran great until last week. (Every now and then it runs rough in gear with your foot on the brakes.) While driving down the road it shut off. It died after lifting from the throttle. It did this 3-4 times. I got it home looked at the battery, connections, everything looks ok. Yesterday the wife called and it would not start. I turned the key to start and only the battery light came on, usually others light up, no fuel pump, no radio. It had 12.8v at the battery and solenoid. I jumped the solenoid several times, it cranked and would not fire. Then the radio, the rest of the gauges, fuel pump and it started with the key. It ran fine all the way home and started this morning. HELP!!![sm=helpout.gif]
Tony
Old Oct 23, 2007 | 06:41 PM
99_GT's Avatar
99_GT
Default RE: Would not start
Sounds like a bad connection on the main 12v power circuit. Check battery connections and at the silonoid. You may have a bad cable.
Old Oct 23, 2007 | 06:46 PM
KELRMN2's Avatar
KELRMN2
Sounds to me like a bad ignition switch or ECM problems.
Old Oct 24, 2007 | 12:17 AM
35thanniz28's Avatar
35thanniz28
must be a ford problem...
Old Oct 24, 2007 | 01:53 AM
5.0stang123's Avatar
5.0stang123
hey 35annivz28 did u join just to make stupid comments? What are u a 12 year old that doesnt like fords? No one gives a **** what you say so why bother posting?
Old Oct 24, 2007 | 07:10 AM
mels50's Avatar
mels50
I am Pretty sure it’s not the battery cable, I checked the volts at the solenoid and it matched the battery (when it would not start). How can I check the ignition switch and the ECM? After it started I turned it off and turned the key forward 15-20 times and started it 9-10 times. It functioned properly every time.
Old Oct 24, 2007 | 06:35 PM
KELRMN2's Avatar
KELRMN2
ORIGINAL: 5.0stang123
damn[sm=insomnia.gif]
Old Oct 24, 2007 | 06:36 PM
KELRMN2's Avatar
KELRMN2
ORIGINAL: mels50
When it doesn't start... what does it do?? Does it click or anything?
Old Oct 24, 2007 | 07:38 PM
mels50's Avatar
mels50
I turned the key forward and there was nothing at the solonoid( no clicking), the fuel pump did not turn on, the radio did not work. I took a screw driver and jumped the solonoid and it cranked but would not fire.
Old Oct 25, 2007 | 06:51 AM
KELRMN2's Avatar
KELRMN2
I would replace the ignition switch.
